My firetv for some reason removed mirror casting, and I really want to take advantage of my note 20 ultra's Dex. Can I use Dex with chromecast?
You can't use it for DeX but you should be able to use it for screen mirroring
Wow that sucks. Any other way to use Dex?
Any specific adapter you'd recommend? Does it plug into the TV via hdmi?Microsoft display adapter will work.
Here is the one we use.
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6852478
Plugs into the HDMI and then to a USB port for power.
Thanks. Any other solutions? That's kind of pricey just for DeX
No way really? Didn't know it worked with Roku. I'll have to test it later.It works with Roku. Maybe you can one of those for a lower price.
A second potential issue is that Wireless DeX is literally a remote display only. Because there’s no hub in the middle—or, in the case of the DeX for Windows, no Windows PC in the middle—you can’t take advantage of an attached keyboard or mouse and use the desktop interactively as you would with a Chromebook, Mac, or Windows PC. That said, you can of course still connect to a Bluetooth keyboard and/or mouse to your phone and go completely wirelessly.
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6858670
