cache11
The iPhone doesn't have 120Hz or 5G either. Turn both off and I'm sure it will be better than the iPhone. Also, the iPhone does about half of what the Note does.
That doesn't sound good. Is your phone faulty? It may be worth speaking to Samsung support about the loss of network.I like my Ultra, but it's not as good as my Note 10+ in some ways. Battery is definitely not as good. Also I'll randomly go to unlock my phone, and it has no network signal. None. Literally won't connect. Have to do a restart. This happens in areas where I generally have good signal, at home for example, so it's not about that.
Yeah happens sometimes on mine , switch lte/3g/2g network modeWe'll see. Since it's not all the time I have a feeling I'll get the run around with Samsung saying it's T-Mobile, and T-Mo saying it's Samsung. I haven't tried resetting network settings or anything yet either. Just noticed it the past couple days. May also try turning 5G off to see if it still happens.
IPhone doesn't do half the things this phone can do. Of course the battery will last longer. IPhones are basic.The battery is a disgrace. My iphone 11 pro max's battery lasts twice as long. Samsung should be ashamed.
Lol , same when it's on 5g just no connection until reboot then I switch network mode been okYours does it too? I can't believe I haven't asked you yet.
Think it's a bug
I thinks so , probably takes a bit from battery alsoMaybe that's what's taking T-Mobile so long on their Sept security update rollout. Trying to fix it.
Mine does it as well.Yours does it too? I can't believe I haven't asked you yet.
my only gripe has been that I can't pay with google pay. samsung pay works so I've started to use that instead.
