Re: Force Dark Mode Resets
Yeah that setting in developer menu doesn't stick after a reboot , just the way it is.
Originally Posted by
mustang7757 Yeah that setting in developer menu doesn't stick after a reboot , just the way it is.
Thank You! As long as that's the way it's supposed to be then there is nothing wrong with my phone. I'm relieved,.
BerryBubbles Thank You! As long as that's the way it's supposed to be then there is nothing wrong with my phone. I'm relieved,.
Yeah it's that way , no worries. Your welcome!
My big wish since the note 10+ is simply that this setting would remain"stuck" after reboot..
Loved the"sunglasses" comment... lol. I thought it was only me that felt that way...
I haven't checked if you can use Bixby for developer options but if possible then I guess you could set up a boot up Bixby Routine
j_hansen I haven't checked if you can use Bixby for developer options but if possible then I guess you could set up a boot up Bixby Routine
Oooooohhhhh! That is an awesome idea..!!
Hmm.. I tried it, but cannot figure how to set it up. I'm probably just not versed enough in Bixby programming.
I love this feature I always have this on now...good to see apps that have never had it suddenly start to have dark mode
MatroxD Oooooohhhhh! That is an awesome idea..!!
Well it might just not be possible yet but they seem to be adding more and more to Bixby Routines all the time so it will be a powerful tool in the future I think
