1. BerryBubbles's Avatar
    Greetings!
    I have never used 'Force Dark Mode' in the Developers Options. My Xfinity apps have been blinding me with their white backgrounds. Xfinity has not incorporated a dark theme that I can find. I enabled the Force Dark Mode setting which makes things so much better, but after a reboot, the option turns off & I need my sunglasses again.
    So my question, is this the standard procedure needing to be toggled on after each reboot, or is something fowl afoot? I'll probably have a hard time remembering to enable the toggle each time.
    Thanks for your help, loving my Note20U.
    mustang7757 and MatroxD like this.
    09-14-2020 05:33 PM
  2. mustang7757's Avatar
    Yeah that setting in developer menu doesn't stick after a reboot , just the way it is.
    BerryBubbles likes this.
    09-14-2020 06:19 PM
  3. BerryBubbles's Avatar
    Thank You! As long as that's the way it's supposed to be then there is nothing wrong with my phone. I'm relieved,.
    mustang7757 likes this.
    09-14-2020 06:33 PM
  4. mustang7757's Avatar
    Yeah it's that way , no worries. Your welcome!
    09-14-2020 06:34 PM
  5. MatroxD's Avatar
    My big wish since the note 10+ is simply that this setting would remain"stuck" after reboot..
    Loved the"sunglasses" comment... lol. I thought it was only me that felt that way...
    09-16-2020 02:50 PM
  6. j_hansen's Avatar
    I haven't checked if you can use Bixby for developer options but if possible then I guess you could set up a boot up Bixby Routine
    MatroxD likes this.
    09-16-2020 03:08 PM
  7. MatroxD's Avatar
    Oooooohhhhh! That is an awesome idea..!!
    Hmm.. I tried it, but cannot figure how to set it up. I'm probably just not versed enough in Bixby programming.
    09-16-2020 03:32 PM
  8. Notefan161's Avatar
    I love this feature I always have this on now...good to see apps that have never had it suddenly start to have dark mode
    09-17-2020 04:42 AM
  9. j_hansen's Avatar
    Well it might just not be possible yet but they seem to be adding more and more to Bixby Routines all the time so it will be a powerful tool in the future I think
    09-17-2020 04:52 AM
  1. Replies: 2
    Last Post: 09-14-2020, 01:16 PM
  2. Can I reset my Phone without the Samsung account?
    Last Post: 09-11-2020, 11:29 PM
  3. Why is my galaxy s20 act like airplane mode but in setting isn’t?
    Last Post: 09-11-2020, 11:09 PM
  4. Galaxy S8 kids mode while touchblock enabled.
    Last Post: 09-11-2020, 02:45 PM
  5. LV v50, one handed mode does nothing now, why?
    Last Post: 09-11-2020, 10:37 AM
