1. Defield's Avatar
    Hi,
    Just gotten my Note20 Ultra last week. Initially when i took selfie photos, i recalled that there's a led ring light that acted as a countdown timer. Now its gone and replaced by the countdown number 54321... Did i disable something by mistake? Thanks.
    09-16-2020 11:55 PM
  2. Mike Dee's Avatar
    Don't recall a red LED. I've always had the timer and a white ring around the camera lens. Does it really matter that much?
    09-17-2020 04:59 AM
  3. Defield's Avatar
    Mike,
    Yes i am referring to that white ring. How do i enable it for selfie camera countdown? Any suggestions?
    09-17-2020 08:38 AM
  4. Mike Dee's Avatar
    Mike,
    I honestly don't know, both show up for me and I don't see a setting. Only thing I can suggest is to reset the Selfie settings Led ring light at front camera-screenshot_20200917-100518_camera.jpeg
    09-17-2020 09:06 AM
  5. Ruben Ocasio's Avatar
    Mike,
    Need to turn timer on.
    Nostromo79 likes this.
    09-17-2020 09:22 AM
  6. Defield's Avatar
    Mike and Ruben,
    I tried my selfie camera with timer on but still couldn't activate the white ring. Searched thru all settings but still could not find any control for it. My selfie camera just shows the countdown number on screen and no white ring light, kinda sad.
    09-17-2020 09:28 AM
  7. mustang7757's Avatar
    Mike and Ruben,
    Yeah my selfie has a circle ring around the camera and countdown.
    Try go into settings of the camera and reset it
    09-17-2020 09:34 AM
  8. Defield's Avatar
    I tried to reset the camera settings, it doesn't work as well. So went to the edge+ lighting to test out the black hole lighting, it's working. Really weird.
    mustang7757 likes this.
    09-17-2020 10:41 AM
  9. Mike Dee's Avatar
    That was my next suggestion
    09-17-2020 10:51 AM
  1. Replies: 15
    Last Post: 09-17-2020, 08:10 PM
  2. AT&T - How To STOP SPAM Texts From Email Addresses...
    By Nickerz in forum General Carrier Discussion
    Last Post: 09-17-2020, 01:35 AM
  3. AT&T 5g in the Chicago suburbs
    By Rmbrown1964 in forum General Carrier Discussion
    Last Post: 09-16-2020, 11:41 PM
  4. Camera is in use by another application and will close.
    By jlost in forum Samsung Galaxy S8 & S8+
    Last Post: 09-14-2020, 11:58 AM
  5. Replies: 6
    Last Post: 11-02-2018, 07:11 PM
