1. felloffthetruck's Avatar
    I had an edge panel called "Soft Key Edge" that would let you do screenshots, power off the display ETC.
    For the life of me I can no longer find this panel. Anyone know where it went or how I can get it on the N20U?
    Is there another panel that is similar?
    Thanks.
    09-17-2020 02:50 PM
  2. j_hansen's Avatar
    Look for one called Tasks
    09-17-2020 02:53 PM
  3. trucksmoveamerica#AC's Avatar
    Thanks.
    Someone said it wasn't ready for the note 20 or something like that. I'm using it and it's working fine. You have to download it from the link below if you want it
    https://www.apkmirror.com/apk/samsun...-apk-download/
    09-17-2020 02:54 PM
  4. nuangel2's Avatar
    that worked for me thanks
    09-17-2020 09:20 PM
  5. novice97's Avatar
    Thanks for sharing
    09-17-2020 10:09 PM
  6. Bosbouer's Avatar
    Edge Panel - Soft Key Edge - Where did it go?-screenshot_20200918-072033_edge-screen.jpgI've still found it in the Galaxy store
    09-18-2020 12:24 AM
  7. trucksmoveamerica#AC's Avatar
Name:	Screenshot_20200918-072033_Edge screen.jpg
ID:	326609I've still found it in the Galaxy store
    That could be. I remember reading somewhere that it wasn't released for the note 20 yet because the developer said it wasn't ready for it. I just found a way to get it without waiting.
    09-18-2020 04:00 AM
  8. felloffthetruck's Avatar
    I'm in the US and cannot find it in the Galaxy Store. How did you find it?
    09-18-2020 09:28 AM
  9. kixfan's Avatar
    He posted the link above in post #3. It's an apk mirror link. It worked for me.
    09-18-2020 09:39 AM
  10. Bosbouer's Avatar
    Opened settings in the edge panel and it was available from the 18th of August when I received and set up the N20U. South Africa XFV software
    09-18-2020 11:33 PM
  11. Bosbouer's Avatar
    Nope, I did not sideload. It's available directly from the galaxy app store.
    09-18-2020 11:35 PM
  12. trucksmoveamerica#AC's Avatar
    You're in south africa it appears. He just said it wasn't in the store, so wondering if it's not available in the United States for some reason.
    I used the link above and there no issues.
    09-19-2020 06:10 AM
  13. SeanD_Colorado's Avatar
    It was not available in the store for me in the US, but the link, which led me to a link with an updated version, worked perfectly. Thanks!
    09-19-2020 08:06 AM
  14. bandofbrothers2112's Avatar
    I'm hoping this option is updated ASAP to get it from the store.
    Apk's make me shudder.
    felloffthetruck likes this.
    09-19-2020 11:43 AM
  15. trucksmoveamerica#AC's Avatar
    To each their own, but this one works fine.
    09-19-2020 08:46 PM
  1. My phone refused to on after charging it during the night
    Last Post: 09-17-2020, 11:46 AM
  2. Calendar Memos Highlighted - cant seem to do it on S8
    By CapeCounty in forum Samsung Galaxy S8 & S8+
    Last Post: 09-17-2020, 11:14 AM
  3. Calendar Memos Highlighted - cant seem to do it on S8
    By CapeCounty in forum Android Apps
    Last Post: 09-17-2020, 10:29 AM
  4. Volume goes up to max on its own...
    By henryfool3 in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 09-16-2020, 06:34 PM
  5. Replies: 2
    Last Post: 09-15-2020, 12:54 PM
