09-20-2020 09:03 PM
42 12
tools
  1. technutcounselor's Avatar
    I have the N20U locked to ATT and three of my friends who were able to send texts 1 week ago are now not able to send them to me, although I can send them out to them. I called ATT and they said everything is fine on my end. Does anyone know what I can do? Is it a cache or carrier settings issue on the phone or just a Verizon issue, which is weird.
    09-17-2020 09:28 PM
  2. mustang7757's Avatar
    Sounds like it on their end , do they have issue with anyone else?
    Laura Knotek likes this.
    09-17-2020 09:43 PM
  3. williams448's Avatar
    If you search these forums and find the threads that discuss SMS/MMS issues, most of them are phones that are locked to At&t. But At&t gives the same answer every time someone calls, it's not on their end. My wife and I had so many issues with our S20U's that we gave up & we both got N20U's. Now, I haven't had any issues, but my wife said last night that she had issues sending pictures or group messages.
    09-17-2020 09:48 PM
  4. Mike Dee's Avatar
    What device did you have before the Note 20?
    09-17-2020 09:50 PM
  5. technutcounselor's Avatar
    I had an iPhone, about 4 weeks ago. This is a recent issue. I've been getting texts until the last week from these same people. Not an imessage issue.
    09-17-2020 10:00 PM
  6. Mike Dee's Avatar
    Do they both have iphones?
    09-17-2020 10:09 PM
  7. technutcounselor's Avatar
    Yes. And they have been able to text up to this last week. Why?
    09-17-2020 10:22 PM
  8. mustang7757's Avatar
    Do the usual steps
    1.Clear the message app Data, cache and Force stop ..those 3 steps and test
    2 . Turn WiFi calling off if u use it
    3. Reset network> setting type reset network in search bar .
    3. Try another message app like Google message app
    09-17-2020 11:00 PM
  9. Mike Dee's Avatar
    There's a minor possibilty that your number is still in the imessage database. If you enter your number at the bottom of this link you'll know for sure.
    https://selfsolve.apple.com/deregister-imessage/
    09-17-2020 11:10 PM
  10. williams448's Avatar
    It's not an iMessage issue. I've never owned an iPhone and I have had the same problems before. It is clearly an At&t issue. In the past while being connected to LTE, I would have to force HSPA+ just so MMS would come through.
    09-18-2020 06:41 AM
  11. Mike Dee's Avatar
    That may be the case but you can't say for certain what the issue is just because you had a similar issue. When we try to help people here we go through a variety of steps to troubleshoot potential issues. Sometimes the advice we offer works and sometimes it doesn't.
    09-18-2020 08:04 AM
  12. mustang7757's Avatar
    We do know Att has this problem since Note 9 I remember , but good point is it MMS messages or SMS thats the issue or both?
    09-18-2020 08:13 AM
  13. williams448's Avatar
    OP should try all suggestions because hell, I know I did. I hope something works for him. But I'm not commenting because I had a similar issue, I'm commenting because it's a known issue with dozens of threads not just here, but on Reddit as well. Android Police even did an article about customers complaining about having issues sending/receiving MMS on At&t's network a few months ago. I'm just letting OP know he's not alone and that his phone is not the problem and it's not a iPhone/iMessage issue.
    mustang7757 likes this.
    09-18-2020 08:16 AM
  14. Mike Dee's Avatar
    As I indicated previously, you may be correct, but we don't know until we try and eliminate the obvious. What did you do to resolve the issue if it's resolved?
    09-18-2020 08:21 AM
  15. williams448's Avatar
    There's nothing to do...you can't do anything about a network issue. I did however change my APN to the NXTGEN APN which has been discussed on here before. I seem to have a little bit better signal strength, but I changed the APN on my wife's phone as well and she said she had MMS issues the other day. It seems to have been isolated to just that day, but still, as much as we pay for our phones & as much as we pay for plans, we shouldn't have repeated network issues.
    09-18-2020 08:29 AM
  16. williams448's Avatar
    I also want to say that I commend you for trying to help your fellow man out. I'm not posting because I think you're wrong and OP shouldn't try your suggestions...I think he should.
    09-18-2020 08:33 AM
  17. technutcounselor's Avatar
    Both
    09-18-2020 01:02 PM
  18. technutcounselor's Avatar
    I'm going to the ATT store after work to see what can be done. I've tried what you all suggested with no luck. I hate that I went to ATT just to get the free N20 (with bill credits) now.
    09-18-2020 01:04 PM
  19. technutcounselor's Avatar
    could changing the SIM card fix it?
    09-18-2020 01:05 PM
  20. mustang7757's Avatar
    It's a possibility if it's old
    09-18-2020 01:07 PM
  21. williams448's Avatar
    He said he went to Att to get the credits, so it sounds like he's a new customer. Either way, I hope OP gets it straightened out.
    09-18-2020 01:12 PM
  22. williams448's Avatar
    Try this... Go to settings>connections >mobile networks>APN. Top of the page you can edit or add APN's. Add this APN. Type it in exactly how you see it here Restart phone after, and give it a try. I get better signal strength with this APN, maybe it can help you.
    Attached Thumbnails Problems receiving texts from Verizon users-smartselect_20200821-001647_samsung-internet.jpg
    09-18-2020 01:15 PM
  23. mustang7757's Avatar
    Doesn't hurt try another sim
    It should be configured correctly if done by store
    09-18-2020 01:28 PM
  24. williams448's Avatar
    Correct, I was just saying it shouldn't be an old card if he's a new customer.
    09-18-2020 01:31 PM
  25. williams448's Avatar
    Doesn't hurt try another simIt should be configured correctly if done by store
    Correct again. But it's been documented by other users, including me that they have had better success with the NXTGEN APN as opposed to the Enhancephone APN. He loses no features, and if he's willing to try it, go for it.
    09-18-2020 01:34 PM
42 12
  1. Canadian Users?
    By Morty2264 in forum OnePlus 8 & OnePlus 8 Pro
    Last Post: 11-07-2020, 11:19 PM
  2. T-Mobile users make sure you're using a 5G SIM card.
    By BigMosley in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 10-11-2020, 10:16 AM
  3. No sounds when receiving a text
    By dj_paige in forum Samsung Galaxy S9 & S9+
    Last Post: 09-21-2020, 05:11 PM
  4. Note20 Ultra - Screen won't turn on for inbound text
    By Jim Stone1 in forum Ask a Question
    Last Post: 09-16-2020, 07:47 PM
  5. watch cannot receive data from phone
    Last Post: 09-16-2020, 03:53 PM
