Does power mode still use 120hz when done through Bixby routines?
This is what it says..but when you try and click on it...it says adaptive can't be used in power mode https://uploads.tapatalk-cdn.com/202...2525c05993.jpg
Re: Does power mode still use 120hz when done through Bixby routines?
Originally Posted by
Notefan161 If you mean the medium power mode trick with 120hz yes it's working you can also see with this app called refresh rate on playstore
https://play.google.com/store/apps/d...eenrefreshrate
Ruben Ocasio Cheers did think damn this does feel smooth as hell lol makes sense if 120hz is still running
Isn't there a thread on 120hz with power saving mode?
Oops too late :)
Ruben Ocasio Is there an app that will give accurate adaptive refresh readouts in different apps on the fly?
evohicks Is there an app that will give accurate adaptive refresh readouts in different apps on the fly?
That app refresh rate shows you if you on 120hz or when it has to drop for certain apps, like opening Google Maps if have 120hz set up on regular settings it drops to 60hz on Map, on gaming , Youtube definitely stays on 120hz and lots of other apps as well, not sure if that's what you was asking.
Ruben Ocasio That app refresh rate shows you if you on 120hz or when it has to drop for certain apps, like opening Google Maps if have 120hz set up on regular settings it drops to 60hz on Map, on gaming , Youtube definitely stays on 120hz and lots of other apps as well, not sure if that's what you was asking.
So is there an app that shows every refresh rate in between 1hz and 120hz that your currently using? Like if an app was using just 10hz for instance.
evohicks So is there an app that shows every refresh rate in between 1hz and 120hz that your currently using? Like if an app was using just 10hz for instance.
The one i posted above shows every refresh rate for any app your on.
Ruben Ocasio The one i posted above shows every refresh rate for any app your on.
OK thanks, I thought the screen was capable of refresh rates of 1hz to 120hz depending on what you are viewing, I can see just 120hz or 60hz using this app.
You can also go to this link and it will tell you how much hertz your screen is putting out without installing the app. https://www.testufo.com/refreshrate
