For those on Sprint, go check Software Update live September Patch is rolling out.
N986USQU1ATI5
N986USQU1ATI5
Got September Patch AT&T Note20 Ultra 5G 512GB //uploads.tapatalk-cdn.com/20200921/8541bd15263d51a7db36367f739f7ad8.jpg
Nothing on my AT&T N20U yet... rebooted and checked a couple of times and still says up to date on August 1 patch.
You're on AT&T... expect the Sept patch in Jan sometime.
Sprint unlocked. Got it last night. View attachment 326771
I also received the patch this morning for TMo. It says updates to Camera quality, do we know any specifics?
Same build number as the others ?Just downloading my TMO update.
Still not sure which firmware AT&T will use , doesn't matter to me , so decided to jump on 1ATI6Nice
Who using AT16 ? Probably be Att if they didn't get 2nd sept build yetStill not sure which firmware AT&T will use , doesn't matter to me , so decided to jump on 1ATI6
At the rate AT&T is going, they may just skip September and just do an October, for Chrissake! It wouldn't be the FIRST time they've skipped a month because of an "Understaffed" Tech Dept situation or maybe it's just sheer indifference!Who using AT16 ? Probably be Att if they didn't get 2nd sept build yet
