1. jejb's Avatar
    On my Note 9, when I would write a screen off note with the Spen, it would toggle a notification, which I'd see the next time I turned the screen on. My Note 20 Ultra is not doing that and I can't seem to find a way to turn it on.
    I was also able to switch the color of the writing on the screen off note on my N9, but can't find a way to do that on the N20 Ultra either. Any way to do that?
    Thanks
    09-22-2020 06:14 AM
  2. debdroid1a's Avatar
    Thanks
    I never tried the notification, so I'm not sure. I just got my N20U and just tried screen off.
    The color change is on the upper left hand corner when you pull the spen. It saves the color as well.
    jejb likes this.
    09-22-2020 06:33 AM
  3. jejb's Avatar
    Thanks for pointing out the color pallet. Can't believe I missed it!
    Anyone know how to make a screen off note trigger a notification?
    09-22-2020 08:51 AM
  4. bbgpsuser's Avatar
    Unfortunately there seems to be a bug in the latest version of Samsung Notes. This notification stopped working on my Note 10+ after the latest Samsung Notes update. Also the notification doesn't work on my Note 20 Ultra.
    jejb likes this.
    09-22-2020 10:09 AM
  5. jimd1050's Avatar
    I just went into "Settings">"Apps">"Samsung Notes" and enabled "Notifications" BUT it looks like "Screen Off Memo" is grayed out so it can't be selected as a choice (even though it appears to be on) - I came back out and refreshed everything, did a test screen note and, you guessed it, no notification still??? Sorry, it was worth a shot! Typical Android cryptic weirdness!
    09-22-2020 10:12 AM
  6. mustang7757's Avatar
    Tap on the words and it will take u to another menu , toggle on pop upsCouple of questions on Notes-screenshot_20200922-113128_settings.jpeg
    jimd1050, jejb and SeanD_Colorado like this.
    09-22-2020 10:32 AM
  7. jimd1050's Avatar
    Tap on the words and it will take u to another menu , toggle on pop upsClick image for larger version.
    "Typical Android cryptic weirdness... NOT! Leave it to Mustang... You da' Man! Thank you Sir...
    Nostromo79, jejb and mustang7757 like this.
    09-22-2020 12:07 PM
  8. bbgpsuser's Avatar
    Still no notification on my Note 10+ nor my Note 20 Ultra.
    jejb likes this.
    09-22-2020 12:32 PM
  9. jejb's Avatar
    Same. Thanks for the above suggestions, but I'd already found and set those things. I'm still not getting the notifications. I guess it's as bbgpsuser says, the application is just broken. I have to say that between the lack of a notification LED and now this, it's tempting to go back to my Note 9. Pretty disappointing when they can't get stuff like this right.
    Yes, I know about AOD, etc. It's just not the same.
    09-22-2020 12:45 PM
  10. mustang7757's Avatar
    Yeah its broken , must be a bug
    jejb likes this.
    09-22-2020 02:46 PM
  11. jimd1050's Avatar
    Yep, I just went back in and specifically selected (General Notifications was already "ON") "Screen Off Memo" On, then for that, selected "Screen Pop-up" On, selected "Sound" on, selected "Ignore DND" and saved! Tried a Screen Off Memo and NOTHING!!! I reset everything back to off... not sure what is the problem, but OP is right!
    mustang7757 and jejb like this.
    09-23-2020 10:45 AM
  12. mustang7757's Avatar
    Its probably a bug , I tried uninstalling the update to the notes app but still same results.
    jejb likes this.
    09-23-2020 11:04 AM
  13. jejb's Avatar
    There was an update on Samsung Notes yesterday. Description said it fixed some bugs, so I was hopeful. But the subject bug persists even after the update. Disappointing.
    JHStewart1023 likes this.
    09-25-2020 05:58 AM
  1. Setup secure and erase on Samsung S8
    Last Post: 09-22-2020, 03:35 PM
  2. Nearby Share not appearing on Share 'apps list'
    Last Post: 09-22-2020, 07:16 AM
  3. [FREE] Smart Note - ML Supported NotePad
    By cecil rhodes in forum Android Apps
    Last Post: 09-21-2020, 04:15 PM
  4. For those of you wanting to use Samsung Credit for the Tab S7...you can't.
    By Flytetymex in forum Samsung Galaxy Tab S7 & S7+
    Last Post: 09-21-2020, 03:45 PM
  5. DND and Drive app issue on Galaxy 8+
    Last Post: 09-21-2020, 02:19 PM
