Mine works fine most of the time. Sometimes I do have to try multiple times. It's certainly not as fast as the unit on the Note 9, for me.
I was wandering around the forums and saw this in the S20 threads. Give it a try. I did and mine is noticably faster even though I didn't have a big problem.
Well hell. That sucks. It seems like one of those deeply buried obscure settings that would be on by default.All of my apps were off already.
I came from the 10+ and it was horrible using the FPS but the note 20 has never failed me so far it's been flawless with a screen protector on and I didn't have to register my prints again.Same here, it works but not consistently, no better than my Note 10 plus, Note 9 was never a problem, worked every time.
I had pretty good luck with the S10+, Note 10+ and S20U FPS, however the Note 20U seems to unlock easier. Hope they didn't skimp on accuracy to get there, but even then I'm sure it would be adequate security.I came from the 10+ and it was horrible using the FPS but the note 20 has never failed me so far it's been flawless with a screen protector on and I didn't have to register my prints again.
It works. Not well, but it works. I had a Note 9 and it was so nice to grab the phone while touching the sensor on the back, at would turn on and unlock in one quick motion. Now I have to fiddle around to power it on the Note 20, then find the right spot on the screen, and press it, and hope it works. It is reliably IF you hit the right spot.
I never understood why so many people doing reviews on the rear fingerprint readers hated them. I liked it, and the in screen reader sucks IMHO.
I have learned to tap the screen two or three times, to get the display on. Then I can locate the location to press my finger on, then hope it works. Two or three more steps then I used to have on the Note 9.
You can set the phone to "lift to wake" the lockscreen so you don't have to tap it.It works. Not well, but it works. I had a Note 9 and it was so nice to grab the phone while touching the sensor on the back, at would turn on and unlock in one quick motion. Now I have to fiddle around to power it on the Note 20, then find the right spot on the screen, and press it, and hope it works. It is reliably IF you hit the right spot.
Save yourself the extra steps. You don't have to power on the screen to use the FPS. Once I got used to it. the process is exactly the same. I pick up the phone while placing my thumb and it's unlocked by the time it's at eye level. You get used to the placement in exactly the same way you developed the muscle memory for where to place your digit on the N9.
Yes very happy with it on my Huawei Mate 20 pro, it's a revolutionary technology and it can only get better. The only time I have issue if my hands are dry after washing them, but a quick moistening fixes that.
That's oddYep, I have that enabled. It seldom wakes / turns on, the phone.
The way I hold it my thumb automatically finds the correct position. Also after using it for the previous 3 devices I'm just pretty much on target even using other digits.Learning that placement is key. On the Note 9, for me, it was pretty automatic because I could feel the surrounding edge. On the N20, it is just a huge smooth expanse of glass. I am going to paint a dot on the case at the edge to help train me. Still annoying that in most cases it takes me so many extra steps to get the screen on and unlocked.
I agree that N9 being sensor on the back being blocked. I often use it as a GPS in a mount. If the N9 screen shut down (it wasn't supposed to, but occasionally happened) I was hosed. No safe way to get it back on while driving. The N20 SHOULD be better in that I can just press the front, IF I can locate the spot.
The way I hold it my thumb automatically finds the correct position. Also after using it for the previous 3 devices I'm just pretty much on target even using other digits.View attachment 326949
Agree as I have had the phone and now returned it...waiting on Samsung to ship the 512mb it’s just memory. It’s a little slow in my opinion compared to apples Face ID but then on the other hand as I type this on my iPhone XS Max the colors are horrid and there are a lot shortcomings on this as well iPhone 11. So no phone is perfect is what I’m saying.
