1. Emperor's Avatar
    I had ATT visual voicemail on my previous phone. Upgraded to Note 20 Ultra (unlocked / purchased directly from Samsung). Google play store is telling me that the ATT software is not compatible with my device. I saw several voicemail apps in the store. Anyone using / recommending a visual voicemail app on their Note?
    09-22-2020 04:37 PM
  2. mustang7757's Avatar
    Should be in galaxy play store, but if you long press number 1 in dialer should prompt to download it there
    09-22-2020 04:42 PM
  3. Emperor's Avatar
    Thanks for the feedback. Issue resolved. ATT Visual Voicemail (VVM) App doesn't work, but the Samsung VVM app works great.
    09-22-2020 10:46 PM
  4. mustang7757's Avatar
    Awesome , glad I could help
    Nostromo79 likes this.
    09-22-2020 10:56 PM
  5. D.P.G.'s Avatar
    Where do you get Samsung VVM and does it work on Sprint? I hate having to pay them monthly to remove advertising.
    09-23-2020 07:09 PM
  6. mustang7757's Avatar
    Samsung visual voice mail for unlocked version should be in galaxy play store , I imitated it by long press the #1 in the dialer and took me galaxy play store to download on my Att sim. I tried with Tmobile sim and said not allowed.
    09-23-2020 08:27 PM
  7. tlc264's Avatar
    I use Google Voice
    09-23-2020 08:43 PM
  8. AndroidFanboy8's Avatar
    I'm with ROGERS WIRELESS and I've subscribed to voicemail to text. Works like visual VM.
    09-24-2020 01:51 PM
  1. Couple of questions on Notes
    By jejb in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-25-2020, 05:58 AM
  2. Connecting Note 10+ to tab s7 Plus
    By encelle111 in forum Samsung Galaxy Tab S7 & S7+
    Last Post: 09-23-2020, 10:23 AM
  3. [FREE] Smart Note - ML Supported NotePad
    By cecil rhodes in forum Android Apps
    Last Post: 09-21-2020, 04:15 PM
  4. Last Note??
    By jlangner in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-21-2020, 01:51 PM
  5. Replies: 4
    Last Post: 09-21-2020, 12:13 PM
