1. felloffthetruck's Avatar
    Got in a replacement Note 20 Ultra set from Whitestone today and they have done away with the blue light cut, improved the glass and alignment tray.
    No mention of blue light cut, the glass is nice and straight across the top now and the alignment tray has a different build # on it.
    I'm in no hurry to install this but just thought I would share my findings.
    Here are a couple pictures of the packaging (old on left, new on right)
    Whitestone Dome Glass - No more Blue Light Cut - Improved Glass & Tray-wsd01.jpgWhitestone Dome Glass - No more Blue Light Cut - Improved Glass & Tray-wsd02.jpg
    pags11 and Serkle K like this.
    09-25-2020 12:59 PM
  2. Talderon's Avatar
    Whoa, last week, they sent me replacements and I got the same "new" ones you got. I may have to try it as the one I have installed now is starting to show Glue Cracking.
    09-25-2020 01:39 PM
  3. Chris134's Avatar
    That usually happens to me two months in. The cracking starts at the side and start working its way around.
    09-25-2020 03:04 PM
  4. Mike Dee's Avatar
ID:	326953Click image for larger version.
    Just because they changed the packaging doesn't mean it isn't. The glass was blue light cut before they mentioned it.
    BTW... ZAGG charges 10 dollars extra for blue light screens
    09-25-2020 04:12 PM
  5. felloffthetruck's Avatar
    The glass and tray are definitely different, blue light no way to tell.
    09-25-2020 04:19 PM
  6. Illuminated_One's Avatar
    Just got a replacement for my mom, since installation on second screen went bad. Kinda lame she gets the updated screen but Im keeping the one I have on right now isn't blue light screen good for you? It wasn't even noticible
    09-25-2020 05:56 PM
  7. Mike Dee's Avatar
    I'm not sure why we need a blue light filter on a screen protector when the device can do it through software automatically.
    felloffthetruck and Ranjen617 like this.
    09-25-2020 06:18 PM
  8. KupKrazy's Avatar
    They've always had the blue light cut before, so just because it doesn't say it wouldn't be any indication that it no longer has it. They only mentioned it on the box for the first time with the Note 20 so they probably got rid of it again because it caused so many questions. If you go to their website, it still says it has it and they are showing the new packaging.
    09-25-2020 11:28 PM
  9. Mike Dee's Avatar
    Yes....I verified it with their rep when the Note 20 came out and it always had before it was listed on the box.
    09-25-2020 11:32 PM
  10. bandofbrothers2112's Avatar
    I received the original version with Blue light and had no issues with installation with the first screen which I then had to remove as the phone went back to Samsung and then no issues with the 2nd screen I installed on the new N20 Ultra.
    Weird how some are experiencing issues and some are not !
    Wonder if it was a batch issue ?
    mustang7757 likes this.
    09-25-2020 11:33 PM
  11. mustang7757's Avatar
    Yeah no issues on mine
    bandofbrothers2112 likes this.
    09-25-2020 11:58 PM
  12. felloffthetruck's Avatar
    Plenty of issues with mine. Both pieces of glass caused shadows on light screens and you could actually see the glass was wavy when looking at it in certain lighting.
    I'll try these new ones sooner or later and report back.
    09-26-2020 05:53 PM
  13. Beth Hahn's Avatar
    I'm still fighting with them for my warranty replacement. Finally went to paypal dispute. Glad to see they upgraded the glass. I've always used their stuff but this glass was horrible. You looked at it the wrong way and it cracked. I gave up and just bought a cheap 15 glass protector kit but used their glue
    So far no issues.
    09-27-2020 08:26 PM
  14. felloffthetruck's Avatar
    The improved version is much more case friendly as it's a little shorter on the top and bottom. Sooner or later I'll get around to installing mine and put up some pictures.
    pags11 likes this.
    10-05-2020 09:18 AM
  15. pags11's Avatar
    Would like to see those pics! Glad they are improving the process and the product.
    felloffthetruck likes this.
    10-06-2020 09:16 PM
  16. bandofbrothers2112's Avatar
    Just had another two pack sent to me via Amazon.
    I'm in the UK.
    One thing I've noticed is that Whitestone are no longer putting x3 vials of adhesive in the two pack boxes !
    Not good if you mess up the 1st application and need to use the 2nd vial leaving you with a 2nd screen protector without adhesive !
    Laura Knotek likes this.
    Today 01:39 AM
  17. Laura Knotek's Avatar
    I'm in the UK.
    Wow! That's not good news, especially given the fact that there is a certain amount of skill and precision to properly install the Whitestone Dome.
    Today 01:48 AM
  18. bandofbrothers2112's Avatar
    They have in the past supplied x3 tubes of adhesive in the twin pack so I'm not sure why they've now stopped this and now only supply 2 tubes !
    Today 02:00 AM
  19. Hermes Hidayat's Avatar
    was about to buy the WSD...then i remembered screwing up so badly for my previous Note 9/S10 and Note 10 and i skipped...
    Today 02:34 AM
  1. Galaxy S8 Quick Reply Notifications No Longer Working
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 09-25-2020, 11:46 AM
  2. No contact details on whatsapp or sms notifications
    By Loopallu in forum Huawei P30 & P30 Pro
    Last Post: 09-24-2020, 07:30 AM
  3. No Media controls in quick menu Android 11
    Last Post: 09-23-2020, 02:27 PM
  4. My NanoGlass screen protector is scratched, no warranty
    Last Post: 09-23-2020, 12:32 AM
  5. Cases & Wireless Charging - OnePlus 8 Pro
    By scottidog in forum OnePlus 8 & OnePlus 8 Pro
    Last Post: 09-21-2020, 12:12 PM
