Originally Posted by
1lamore Exactly! How do you block it. Is it just ignoring it, by not pressing update? I thought I had a button on my Sprint Note 8 that said "Auto Update" for Apps as well as ex. UI2. I would get notifications about the update, but it would not just do it.
I use as a app from playstore called package disabler pro for Samsung and disable it there, you don't even get the notifications.
Mustang7757 or Mikedee can tell you the exact ones to disable. I was just looking at this when you posted this question. I also disable all the bixby crap. Just be careful and make sure you know what you're disabling.
