1. 1lamore's Avatar
    I know most people are just using Samsung Notes, but I had the app for SNote on my Note 8 - with the weekly planner template - and when I switched to the Note 20 Ultra, my "note" were loaded into the Samsung Notes as @ pictures. At least I still had my info. I tried to reload the apk I used on my Note 8 - it said it installed but was blank. I searched and found an apk listed on Sammobile, that was loaded there 2 months ago. I installed it on my phone and poof it is there!! It even took the info off the saved files from the SSwitch. No new templates, but I can copy over old ones. Hope this helps anyone else with this issue!
    EMGSM, jejb and jimd1050 like this.
    10-07-2020 02:45 PM
  2. mustang7757's Avatar
    Thanks for sharing your experience and fix
    10-07-2020 03:00 PM
  3. EMGSM's Avatar
    I did the same thing. For the most part I assumed that people switched to Samsung Notes. Glad S Note still gets some love because I still use it
    1lamore likes this.
    10-08-2020 03:17 AM
  4. jejb's Avatar
    Thanks for this. Does it fix the issue where no notification is posted for screen off memos?
    10-08-2020 07:22 AM
  5. 1lamore's Avatar
    I don't know about that. I pretty much use just the Weekly Schedule like a work diary. Like I said, it wouldn't work with the older apk - but the one on Sammobile, posted 2 months ago did. But that version didn't have the templates that I love. I had downloaded an apk called "Add Snote Templates" 3 years ago, and that is where I get the Schedule template I use. This was transferred from my Note 8, and after the new download from Sammobile - I could go to that "app" and add the template I wanted. It didn't allow that before the new download. Hope that helps.
    10-08-2020 08:02 AM
  1. Edge of the Note 20, versus Note 4
    By tee_cup in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 10-16-2020, 09:14 AM
  2. Pls how do i unhide private space on my gionee s11 lite
    Last Post: 10-07-2020, 08:54 PM
  3. why would my rebel tracphone have very low volume on incoming calls ?
    Last Post: 10-07-2020, 08:53 PM
  4. ONE UI 2.5 Problems on AT&T Note10+
    By cogic740 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-07-2020, 01:24 PM
  5. do i need adapter to hdmi to hookup my samsung a21 to tv,
    Last Post: 10-07-2020, 11:48 AM
