10-17-2020 10:14 PM
28 12
tools
  1. jhnnyblze2000's Avatar
    Ok so I put my SIM card in a Verizon branded galaxy s20 plus and it got the update and now gets 5g. Pull the SIM card and stick it in my unlocked note 20 ultra and no update and no 5g. Is there anything I can or have to do to get 5g on my Note?
    10-17-2020 07:58 PM
  2. mustang7757's Avatar
    Hi, Verizon funny on this , maybe wait until a update is out for this new Verizon 5g or flash it to carrier firmware
    10-17-2020 08:20 PM
  3. jhnnyblze2000's Avatar
    I’m looking for the firmware and Odin to download now plus how too. Been a long time since I’ve done this LOL.
    10-17-2020 08:21 PM
  4. mustang7757's Avatar
    No problem I can help.
    10-17-2020 08:28 PM
  5. Mike Dee's Avatar
    Haven't heard of it released yet for the Note
    10-17-2020 08:28 PM
  6. mustang7757's Avatar
    This is the steps :
    Windows computer needed
    Latest Odin can Google it from XDA Forums and download the latest should be Odin 3.14.1 / and Frija tool or samfirm (i usually download both)
    Download samfirm v0.4.1 tool and frija, extract it with 7zip.
    You will extract files for Odin prince comsey/xda has this 3.14.1once download with 7zip and will do same for firmware with 7zip .
    Put your model number then region and select check for updates , then download the FIRMWARE , extract the FIRMWARE with 7zip.
    There will be 4 files after you extract the firmware
    BL
    AP
    CP
    CSC
    Each of those files will go in Odin when you open to the corresponding slots
    BL
    AP
    CP
    Home slot don't out anything
    CSC USE HOME CSC FIILE TO SAVE DATA /THIS ONLY GOING BETWEEN CARRIER FIRMWARE OR IF YOUR ON UNLOCKED GOING BETWEEN UNLOCKED FIRMWARE
    If you going from carrier to unlock firmware keep regular CSC not home CSC and do a back up it will factory reset the device.
    connect your phone with cable to computer , once the files are in its slots hit start, once done you'll see pass in Odin and it will reboot
    *Make sure you put phone in download mode
    *If dont see your phone connected in Odin change cables or ports in computer .
    *Never disconnect the cable in middle of flashing.
    carlitobahsoun likes this.
    10-17-2020 08:30 PM
  7. jhnnyblze2000's Avatar
    This is the steps :
    BL
    AP
    CP
    CSC
    BL
    AP
    CP
    If I’m going from unlocked to carrier is use vzw for the csc if I’m trying to go to Verizon software?
    10-17-2020 08:50 PM
  8. mustang7757's Avatar
    Yeah when you extract the 4 files from Verizon carrier firmware put those in 4 corresponding slots in Odin. Csc use the regular not home csc
    10-17-2020 08:52 PM
  9. jhnnyblze2000's Avatar
    Ok one more question. When I search frija for the firmware. Where it says model number. Do I out the one given in my settings or the model number for the Verizon note 20 ultra?
    10-17-2020 09:15 PM
  10. mustang7757's Avatar
    Keep the U at the end and leave out #1 at the end
    10-17-2020 09:21 PM
  11. jhnnyblze2000's Avatar
    That gives me an unable to find firmware. Leaving the 1 pulls up firmware.
    10-17-2020 09:23 PM
  12. mustang7757's Avatar
    SM-N986U1 is the unlocked
    SM-N986U is carrier
    Note 20U
    10-17-2020 09:28 PM
  13. jhnnyblze2000's Avatar
    SM-N986U is carrier
    Note 20U
    Hmm I dunno then. When I search without the 1 it doesn’t find anything.
    10-17-2020 09:29 PM
  14. mustang7757's Avatar
    You put region VZW ?
    10-17-2020 09:31 PM
  15. jhnnyblze2000's Avatar
    Yup in samfirm I put Model SM-N986U Region VZW
    In Frija I put Model SM-986U CSC VZW it asks for CSC not region in frija.
    10-17-2020 09:33 PM
  16. mustang7757's Avatar
    Yeah its same csc and region
    So frija u found it ?
    10-17-2020 09:36 PM
  17. jhnnyblze2000's Avatar
    With the 1 on the end and vzw for csc.
    10-17-2020 09:36 PM
  18. mustang7757's Avatar
    And samfirm?
    10-17-2020 09:38 PM
  19. jhnnyblze2000's Avatar
    And samfirm?
    Same. With the 1 it comes up without it doesn’t
    10-17-2020 09:39 PM
  20. mustang7757's Avatar
    Can you show screen shot what it says when you load it with SM-N986U vwz?
    10-17-2020 09:47 PM
  21. jhnnyblze2000's Avatar
    10-17-2020 09:49 PM
  22. mustang7757's Avatar
    What if you put TMB in csc ?
    10-17-2020 09:54 PM
  23. jhnnyblze2000's Avatar
    That worked.
    10-17-2020 09:54 PM
  24. mustang7757's Avatar
    That worked.
    Use that one , all carrier are interchangeable
    10-17-2020 09:59 PM
  25. jhnnyblze2000's Avatar
    Ok thank you. I’ll still get all the Verizon updates when they release them?
    10-17-2020 10:00 PM
28 12
  1. Gallery on Android 8.1
    By wquatan in forum Ask a Question
    Last Post: 10-19-2020, 11:11 AM
  2. Can I get some different advice on how to get rid of this hacker?
    Last Post: 10-17-2020, 07:50 PM
  3. Pixel Visual Voicemail work on Mint Mobile
    Last Post: 10-17-2020, 07:37 PM
  4. Change of number on samsung account without access to old number
    Last Post: 10-17-2020, 03:45 PM
  5. Wifi doesn't work after using Dr. Fone on Samsung J510FN - what can I do?
    Last Post: 10-17-2020, 03:43 PM
