    I don't get how to use this properly. If I capture a whole article or something then it squeezes it all on to the screen as a really thin tiny capture so makes it impossible to write on and doesn't seen like it's possible to zoom in. Am I doing something wrong?
    10-18-2020 05:51 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Can you zoom in with a pinch gesture?
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    10-18-2020 05:52 PM
  3. williamsn8911's Avatar
    I'm on the note 20 ultra. You can zoom in but there's a weird view that doesn't seem to allow you to keep the page in place.
    10-18-2020 06:00 PM
  4. williamsn8911's Avatar
    This is the weird view. I just want it to lock in place so it fits the width of the screen and I can just scroll down as I would on the original article.
    Attached Thumbnails How to use screen write with scroll?-screenshot_20201018-230306_samsung-capture.jpg
    10-18-2020 06:10 PM
  5. B. Diddy's Avatar
    Let me ask someone who's more familiar with Samsung. @mustang7757, comments?
    mustang7757 likes this.
    10-18-2020 08:36 PM
  6. mustang7757's Avatar
    Thats smart select for spen, let's you extract texts to copy and share
    Ranjen617 and husslord like this.
    10-18-2020 09:12 PM
  7. williamsn8911's Avatar
    No, it's screen write. The white area is what
    gets saved when you're done. But if you zoom in to try and fit to the phone screen it moves all over the place.
    Attached Thumbnails How to use screen write with scroll?-screenshot_20201019-213939_samsung-capture.jpg
    10-19-2020 04:44 PM
  8. mustang7757's Avatar
    Ahh yea , screen write but I'm not having the issue your explaining
    10-19-2020 09:33 PM
  9. mustang7757's Avatar
    [Moved this to Note 20 forums for specific traffic]
    10-19-2020 09:35 PM
  10. williams448's Avatar
    Move the corner of the highlighted area in or out (white corner bars). Kinda like resizing a window on a computer screen.
    10-19-2020 10:04 PM
  11. mustang7757's Avatar
    I did , no issues... I even pinched in and out with my fingers .
    10-19-2020 10:25 PM
  12. williamsn8911's Avatar
    Yeah, I can move the white area, but when I zoom in or out the white area doesn't stay with the area of the image. And also, the whole image shifts around rather than just scrolling up and down as it would on the original article/webpage.
    10-20-2020 06:43 AM
  13. mustang7757's Avatar
    Try resetting Air Command , go settings >apps >air command tap it> storage and clear data/cache then force stop it .
    10-20-2020 09:19 AM
  14. bbgpsuser's Avatar
    I think that you are expecting the selection area to grow/shrink along with the picture underneath when you are resizing that picture?
    That is not the normal photo editor behavior. When you edit an image in gallery, if you zoom in on a picture the selection size does not track the outside of the photo. The selection area remains the same and it results in a cropped image.
    10-20-2020 12:33 PM
  15. debdroid1a's Avatar
    I'm not having your problem if I'm understanding correctly. My edges stay wide and don't change when I pinch in to write. They stay the same when I don't pinch and then when I do. See attached photo.
    What phone, provider, etc.? Mine is tmobile, USA, locked.
    eta just thought. Are you pinching with the spen or your fingers? I'm using my fingers.
    Also, are you pinching in the center and not the side? When I pinch with my fingers on the side, the white edges move. Otherwise it stays to the edges.
    10-20-2020 05:56 PM
  16. jimd1050's Avatar
    On mine, if you go to "Air Command" and click "Screen Write" there, there's a tab for "Scroll Capture" that pops up and all you do is either keep tapping it until you've got all you want or just hold it down if you want the entire page! Then, you just hit save!!! Instruction jpg attached!How to use screen write with scroll?-img_20201027_174038.jpeg
    10-27-2020 05:48 PM
  1. Hole punch necessary in screen protector?
    By THEPRFCT10 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 10-22-2020, 11:16 PM
  2. How can I get the lock screen function back on my Alcatel Raven A574BL?
    Last Post: 10-18-2020, 05:55 PM
  3. Replies: 1
    Last Post: 06-12-2018, 05:11 PM
  4. how to read locked sim card numbers
    Last Post: 01-16-2018, 01:36 PM
