1. 1lamore's Avatar
    I finally found how to get the "Tap to Answer" back on the phone. I think they took it away on Pi, and since I just got this phone with Android 10 - I assumed it wasn't there (and after looking with no avail). It is hidden, in my estimation, under Assistant Menu.
    1st - Accessibility>Interaction and dexterity>Assistant Menu. Hard press Assistant Menu - takes you to a new menu. Then you unfortunately have to turn on the Assistant menu>Single tap to swipe. So we have to have the Assistant menu (a little button) on the screen or as a side button in order to keep the "tap to Answer" on. I made it be a side button and made it transparent so I don't notice it because I won't use it. Now, I can tap to answer calls, to dismiss alarms ect. !!! Hope this helps anyone else that has been looking and hoping to get that function back.
    Talderon, burrzoo, tube517 and 1 others like this.
    10-19-2020 07:45 AM
  2. mustang7757's Avatar
    Thanks for your tip , it was available since pie , but you had small circle menu would appear until you drag it to the top and placed it on the X . I remember going over this in Note 9 forums at the time.
    10-19-2020 09:06 AM
  3. 1lamore's Avatar
    It doesn't seem to be able to be taken off now. I tried to drag it, but no X shows up. I have it floating on the side, barely able to be seen.If I could get rid of it, that would be great, but if not, I'll just keep it.
    10-19-2020 11:45 AM
  4. mustang7757's Avatar
    Yeah your right , it doesn't give that option any longer
    10-19-2020 11:51 AM
  1. How to use screen write with scroll?
    By Android Central Question in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 10-27-2020, 04:48 PM
  2. Replies: 1
    Last Post: 06-12-2018, 04:11 PM
  3. how to read locked sim card numbers
    Last Post: 01-16-2018, 12:36 PM
  4. My phone has refused to come on or charge
    Last Post: 11-06-2016, 01:30 PM
