10-27-2020 11:10 PM
57 123
tools
  1. Lecrae116's Avatar
    I just noticed this. Do I need to activate it or is it a waste of battery and time?
    10-19-2020 09:44 AM
  2. LordAndroid's Avatar
    I just noticed this. Do I need to activate it or is it a waste of battery and time?https://uploads.tapatalk-cdn.com/202...8bf1451657.jpghttps://uploads.tapatalk-cdn.com/202...f6cf6b7cf6.jpg
    I don't have this option available on mine
    jimd1050 likes this.
    10-19-2020 09:50 AM
  3. sweetypie31's Avatar
    I don't have that either .
    10-19-2020 09:52 AM
  4. Hermes Hidayat's Avatar
    For my Samsung devices i always turn it on... Not sure if its good but no issues so far.
    10-19-2020 10:03 AM
  5. Lecrae116's Avatar
    I bought mine unlocked from Samsung directly and never had this option on my carrier versions of the note.
    10-19-2020 10:12 AM
  6. sweetypie31's Avatar
    Ok I'm carrier locked so that could be an unlocked thing.
    SeanD_Colorado likes this.
    10-19-2020 10:19 AM
  7. mustang7757's Avatar
    Its been for some time now that option, I have mine off
    TheMiz likes this.
    10-19-2020 10:41 AM
  8. Lecrae116's Avatar
    I accidentally turned the virus scanning ON and I don't know how to turn it back off
    10-19-2020 10:42 AM
  9. mustang7757's Avatar
    Let me see if there option to turn off
    10-19-2020 10:43 AM
  10. mustang7757's Avatar
    Well I turned it on to see if it can be turned off lol , I reset device care that didn't do it , so now you gave me something to look into a little later
    10-19-2020 10:52 AM
  11. Lecrae116's Avatar
    Yay?
    10-19-2020 10:55 AM
  12. TheMiz's Avatar
    Why do you want to turn it off ? It is not running in the background only when you click scan.
    10-19-2020 11:39 AM
  13. B. Diddy's Avatar
    Well, at least they're not using Qihoo 360 Security any more.
    10-19-2020 11:57 AM
  14. Gayle Lynn's Avatar
    In order to protect it has to be active and running.
    McAfee is a lot more trustworthy than what they use to have to offer. But, no I don't think it is needed or wanted. If I did, I'd first turn to Malwarebytes and AdGuard Pro.
    Clearing memory on a 8-12GB RAM phone? How long has the virus scanner been under device care?-screenshot_20201019-115251_samsung-20internet-20beta.jpeg
    B. Diddy likes this.
    10-19-2020 11:58 AM
  15. B. Diddy's Avatar
    "Memory Booster" GRRRRRRRRRRRRR
    10-19-2020 12:25 PM
  16. jlangner's Avatar
    The option isn't on my t-mobile. During setup I told not to do McAfee..Did you? If not wonder if it is the McAfee and you have to disable it?
    Ranjen617 likes this.
    10-19-2020 12:44 PM
  17. mustang7757's Avatar
    Your on unlocked?How long has the virus scanner been under device care?-screenshot_20201019-135512_device-20care.jpeg
    10-19-2020 12:55 PM
  18. jlangner's Avatar
    Your on unlocked?Click image for larger version.
    T-mobile locked...forgot you were unlocked.
    mustang7757 likes this.
    10-19-2020 12:58 PM
  19. mustang7757's Avatar
    I forget does carrier version have this?
    10-19-2020 01:23 PM
  20. mustang7757's Avatar
    Yay?
    Found it
    This will deactivate it
    Go settings >top search bar type device security scroll to end of the list and tap , clear its data,/cache and force stop it .How long has the virus scanner been under device care?-screenshot_20201019-145727_settings.jpeg
    10-19-2020 01:58 PM
  21. jlangner's Avatar
    No, not on mine
    10-19-2020 02:25 PM
  22. mustang7757's Avatar
    No, not on mine
    Yeah , I think carrier took it out on their firmware
    10-19-2020 02:28 PM
  23. Lecrae116's Avatar
    We both learned something today.
    10-19-2020 02:39 PM
  24. mustang7757's Avatar
    Yes we did
    10-19-2020 03:29 PM
  25. D.P.G.'s Avatar
    I have an unlocked phone bought from Samsung on Sprint and this has been there since the day I got the phone I believe August 21st. I would also like to know how to disable it because it scans on it's own. Clearing the data and cache doesn't work. Forcing it to stop only works until I restart the phone or run Device Care would like a permeant deactivation.
    10-19-2020 06:33 PM
57 123
  1. my smart tv shows,"tvservice has stopped"
    By Android Central Question in forum Android TV
    Last Post: 10-20-2020, 12:41 PM
  2. [Solved] Android bluetooth has stopped sharing....keeps repeating
    Last Post: 10-19-2020, 12:06 PM
  3. My gionee f100 lost its camera and the icon is missing what could be the problem?
    Last Post: 10-19-2020, 12:04 PM
  4. Creating new user on android device
    Last Post: 10-19-2020, 08:30 AM
  5. my smart tv shows,"tvservice has stopped"
    Last Post: 10-19-2020, 04:30 AM
