Unlocked Note 20 Ultra Question
amyf27
9,907
277
83
I'm going to pick up an unlocked Note 20 Ultra at Best Buy here shortly. Just occurred to me it probably won't have a sim card since it's unlocked, correct?
Correct although they let you pick a carrier to activate with so I presume if you do that they will give you a sim card.
It should have a sim card tray. Unlocked just refers to the device being able to use on any carrier
Got my number moved onto the new phone - loving it. Only issue - now the S20 won't allow me to use Samsung Smart Switch - something about a ssecurity policy. It appears to be on the S20's side not the Notes. Wondering if I should factory reset the new Note20 Ultra and try again?
I hate to say it, but might be better to simply setup as 'new'. Yes, it takes longer. But...
That's odd....what security policy?
I think it was something dumb. After I reset that phone I got into my samsung account fine and likely could've with the smart switch as well. When I had purchased that S10, Smart switch worked fine. Probably just some odd glitch
