Smartwatch is connected. Not sure about wifi directDo you have a smartwatch connected? Maybe WiFi Direct?
It could be a printer or any other device.Not smart watch... had this icon a while ago and now can't remember what it was...
Unlocked versionWhich carrier Verizon? Maybe wifi extender?
Sprint still. When I'm connected to a wifi network and pull down the notification bar the icon isn't there anymoreWhich carrier sim?
Hmmm...Sprint still. When I'm connected to a wifi network and pull down the notification bar the icon isn't there anymore
As long as I'm connected to a mobile network.Hmmm...
How long it stays in status bar ?
Must be. Not sure how to turn it OFF.That is a WiFi direct symbol
Go to settings >apps >3 dots tap> system apps >scroll all the way down to wifi direct tap>storage clear data/cache then force stop itMust be. Not sure how to turn it OFF.
Did all that but when I reopen wifi direct again I'm presented with the same screenshot I just posted but the wifi icon with the arrows is gone when I'm on mobile data. So I don't know what to think.Go to settings >apps >3 dots tap> system apps >scroll all the way down to wifi direct tap>storage clear data/cache then force stop it
Is it connected to anything there or just trying?Did all that but when I reopen wifi direct again I'm presented with the same screenshot I just posted but the wifi icon with the arrows is gone when I'm on mobile data. So I don't know what to think.
It looks like it's in "search and scan" mode. Not showing it's connected to anything or found anything in rangeIs it connected to anything there or just trying?
If so just clear it out one more time and don't restart it .
Ok , did you repeat what I mentioned before?It looks like it's in "search and scan" mode. Not showing it's connected to anything or found anything in range
