Yes everything works like carrier version on Tmobile unlocked , had to rebootHave you tried this out?
If your unlocked , no need to flash use this method to get carrier featuresCool I gonna keep this in mind for tomorrow's project... Thinking about flashing to Tmo like I did the N10+ as well
That's great.... Appreciate the post!If your unlocked , no need to flash use this method to get carrier features
Thank you
On Verizon , I don't think this method worksUnlocked on Verizon, no RCS still
Correct, I tried it and no luckOn Verizon , I don't think this method works
Unbelievable with Verizon, you also reboot and Uninstall Google message app? You have carrier service app installed?Correct, I tried it and no luck
I did all of that except the uninstall of Messages. That one I just turned off the Chat feature.Unbelievable with Verizon, you also reboot and Uninstall Google message app? You have carrier service app installed?
Yeah Verizon issue then , ill have to test Att , this on my TmobileI did all of that except the uninstall of Messages. That one I just turned off the Chat feature.
Force stop your message appIt doesn't work for unlocked on AT&T.
