Save big + get 3 months free! Sign up for ExpressVPN today
  1. MozzaJ's Avatar
    Hi
    I'm just wondering if I have a faulty camera on my Ultra as I'm really not impressed by the picture quality. Is it a problem with my camera or are others experiencing the same?
    If you have a look at the 2 photos attached, one with my old Note 8 and one with my new 20 Ultra you'll see that the Note 8 captures the sunlight and the clouds accurately i.e. a bright yellow sunshine and dark grey clouds but the 20 Ultra turns the sunlight into this orange blur and lightens the color of the clouds. The odd thing is that when I view the motion picture of the same picture on the 20 Ultra then the sunlight is realistic while the picture is playing. It's only when the motion stops and the end picture is presented that it returns this horrible orange color.
    I don't have any filters on that I'm aware of. Anybody any thoughts or suggestions?
    Thanks
    John
    Attached Thumbnails Camera issue on Note 20 Ultra-note20.jpg   Camera issue on Note 20 Ultra-note8.jpg
    11-18-2020 02:38 AM
  2. Hermes Hidayat's Avatar
    did you focus on the same spot?
    11-18-2020 02:52 AM
  3. MozzaJ's Avatar
    Note 20 was taken using the suggested "Best shot". Neither were really focused. Just point and click.
    It seems to change sunshine to an orange shade with any picture involving sunlight.
    11-18-2020 06:37 AM
  4. Hermes Hidayat's Avatar
    Should try with the same spot focus. AI usually gives what it thinks is best.
    11-18-2020 07:04 AM
  5. MozzaJ's Avatar
    I'd be surprised if it was just because I hadn't focused as it had already selected what it thought was the best shot.
    Here's another picture where it's decided to turn the picture orange. I'm just wondering if this is normal for the phone, which I doubt, or if there's something wrong with mine?
    11-18-2020 07:41 AM
  1. automate airplane mode on/off for home wifi calling
    By neighner in forum Ask a Question
    Last Post: 11-19-2020, 07:59 AM
  2. [18/NOV/20] ZTKD 5th Android 11 Beta for Global S20's
    By ironass in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 11-17-2020, 10:46 PM
  3. Android 10 Samsung a10e show seconds on clock?
    Last Post: 11-17-2020, 10:10 PM
  4. Issues with some technical stuff
    By CharlyNews in forum ZTE Axon 10 Pro
    Last Post: 11-17-2020, 09:21 PM
  5. Replies: 4
    Last Post: 11-17-2020, 10:34 AM
