Haven't used it in years. What functions will I be missing using Nova Prime? Will I lose spen features, edge panels, edge lighting, etc.?
You will miss none of those that you just mentioned. You still get those plus gain all the features from Nova. Just try it.
One can do that now with Nova. I too use Nova on my 5GU. When I go left that's my Google News Screen. That was enabled a year or so ago-ish. HTHI miss the left Google now news screen from my pixel... active know is the nova sideload mod still works? Seems like it's not maintained.
My best attempt of a screenshot sliding left showing you.I miss the left Google now news screen from my pixel... active know is the nova sideload mod still works? Seems like it's not maintained.
Is it built in or did you have to sideload?One can do that now with Nova. I too use Nova on my 5GU. When I go left that's my Google News Screen. That was enabled a year or so ago-ish. HTH
Integrated. I assume it's on all versions now enough though this says beta. But I've been in their beta program for years.Is it built in or did you have to sideload?
I don't have that integration... guessing you sideload the module that integrates at some point?Integrated. I assume it's on all versions now enough though this says beta. But I've been in their beta program for years.
It is quite useful when you get used to it. Usually we go to an specific app (browser, YouTube, Spotify, app drawer ...) and then type a search. With Sesame it's the other way around. You trigger the search with a gesture, type and then select where you want to make the search. Quick and powerful, worth a try.I've been using Nova Launcher since my S8, Note 8 and now N20U with no loss of features whatsoever.
I'm not sure how useful Sesame is though, since I've already paid for Nova Prime.
