1. o4liberty's Avatar
    I tried running my note on optimized for a couple of months but personally it slowed it down too much. Power mode is so much faster for me what is everyone else doing?
    11-24-2020 01:25 PM
  2. kixfan's Avatar
    Mine is set on High performance too. My thinking is why have a flagship device and not use it at maximum potential. I always have a charger near me anyway but battery life has never been an issue with this phone. After an 8 hour work day I still usually am at 60% or more.
    11-24-2020 01:31 PM
  3. mustang7757's Avatar
    I went between optimized and high performance, but I'm on android 11 beta looks like that option gone.
    11-24-2020 01:35 PM
  4. Lecrae116's Avatar
    So what options does android 11 give you?
    11-24-2020 01:45 PM
  5. Lecrae116's Avatar
    Does anyone use "adaptive battery" and "adaptive power saving"?
    11-24-2020 01:46 PM
  6. mustang7757's Avatar
    It gives you these options now , 2nd picture in device care enhanced processing Power mode-screenshot_20201124-134648_device-20care.jpegPower mode-screenshot_20201124-134711_device-20care.jpeg
    Jerry Schuller likes this.
    11-24-2020 01:48 PM
  7. Lecrae116's Avatar
    It gives you these options now , 2nd picture in device care enhanced processing Click image for larger version.
ID:	329162Click image for larger version.
    Do you think its better or worse than it was before android 11?
    11-24-2020 01:57 PM
  8. mustang7757's Avatar
    Good question, haven't come to a conclusion yet .
    11-24-2020 01:58 PM
  9. mustang7757's Avatar
    I can tell you the new battery usage stats is better.
    11-24-2020 02:00 PM
  10. Lecrae116's Avatar
    When is the official release date of Android 11?
    11-24-2020 02:07 PM
  11. mustang7757's Avatar
    I'm thinking as far as S20 and Note 20 series should be sometime in December , the others be January or February .
    11-24-2020 02:08 PM
  12. Lecrae116's Avatar
    What mode do you recommend is best for battery life and performance?
    11-24-2020 03:16 PM
  13. mustang7757's Avatar
    Optimized
    11-24-2020 03:40 PM
  14. Lecrae116's Avatar
    Optimized
    With or without "adaptive battery & adaptive power saving"
    11-24-2020 04:25 PM
  15. mustang7757's Avatar
    Without adaptive, with adaptive it can go medium power save mode and delay notification and performance
    11-24-2020 04:41 PM
  16. BerryBubbles's Avatar
    I leave my phone set to Optimized. Now that I am using my tablet more, my N20U battery last for days.
    11-24-2020 05:44 PM
  17. Lecrae116's Avatar
    Which one does this? Is it Adaptive power saving or Adaptive battery?! I'm confused.
    11-24-2020 05:50 PM
  18. mustang7757's Avatar
    Adaptive power mode can change to medium power mode.
    Adaptive battery will put unused apps to sleep
    11-24-2020 06:47 PM
  19. Lecrae116's Avatar
    So your just saying to leave adaptive battery enabled and leave adaptive power saving disabled,correct?
    11-24-2020 06:58 PM
  20. mustang7757's Avatar
    Correct
    Lecrae116 likes this.
    11-24-2020 07:05 PM
  1. DeX mode
    By alteon57 in forum Samsung Galaxy S9 & S9+
    Last Post: 11-25-2020, 04:16 PM
  2. can't pull down notification bar in portrait mode
    Last Post: 11-25-2020, 03:19 PM
  3. Replies: 15
    Last Post: 11-24-2020, 08:50 PM
  4. My phone is on fastboot mode and i cant remove it please help what should I do
    Last Post: 11-23-2020, 02:06 PM
  5. Xperia Z5 Premium - Power button not working - can't get into fastboot mode?
    Last Post: 11-21-2020, 10:27 PM
