1. frederickdawg's Avatar
    When calling 611, is one supposed to see an HD calling icon on the dialler when the call is being placed using cellular, with wifi off? My previous non american note 20 ultra did. Was wondering if this is normal behavior . Cheers.
    11-25-2020 02:59 PM
  2. o4liberty's Avatar
    I purchased my note from Tmobile and never saw that icon yet.
    frederickdawg likes this.
    11-25-2020 06:45 PM
  3. BerryBubbles's Avatar
    I never noticed an icon as you described, but that doesn't mean it wasn't there. My US N20U on T-Mobile is an unlocked model, as you mentioned in the title, so that might be a factor. Maybe, the icon doesn't appear on the unlocked model.
    11-25-2020 07:18 PM
  4. Hermes Hidayat's Avatar
    When calling 611, is one supposed to see an HD calling icon on the dialler when the call is being placed using cellular and wifi off? My previous non american note 20 ultra did. Was wondering if this is normal behavior . Cheers.
    I always have that HD icon when a call is placed...
    11-25-2020 08:05 PM
  5. frederickdawg's Avatar
    The Hong Kong one I had before showed the HD calling icon on the dialler also. But the U1 american one doesn't.
    11-26-2020 01:47 AM
  6. frederickdawg's Avatar
    Looks like it's normal for it not to show then. Thanks.
    I could have sworn on my previous american usa spec samsung s10+ and note 9 it did. Maybe they got rid of that eye candy. But I believe calls are still HD via volte just doesn't show it.
    BerryBubbles likes this.
    11-26-2020 01:48 AM
  7. BerryBubbles's Avatar
    I do remember seeing it on my locked T-Mobile s9+. I'll be watching for it now.
    mustang7757 and frederickdawg like this.
    11-26-2020 05:40 AM
  8. mustang7757's Avatar
    On carrier Tmobile yes it was there , on unlocked Tmobile don't remember seeing it .
    11-26-2020 10:54 AM
  9. frederickdawg's Avatar
    Aww , that's a good point. I almost forgot the s10 plus I had was carrier version.
    mustang7757 likes this.
    11-26-2020 06:41 PM
  10. mustang7757's Avatar
    Carrier phones usually show all that .
    11-26-2020 09:38 PM
  1. Why can't i call a specific phone number?
    Last Post: 11-28-2020, 08:37 PM
  2. Zoom Call
    By Toejam in forum Pixelbook Go
    Last Post: 11-27-2020, 01:21 PM
  3. T-mobile November patch 11/24
    By Ryano89 in forum LG V60 ThinQ
    Last Post: 11-27-2020, 07:08 AM
  4. Audio random cut out on mobile
    By Maccauk11 in forum General Help and How To
    Last Post: 11-25-2020, 01:11 PM
  5. Xfinity Mobile Service?
    By lgbalfa in forum General Carrier Discussion
    Last Post: 11-24-2020, 06:09 PM
