dont see any info on this other than android made some changes a while back stopping those apps from working. anything avail to hide or disable apps completely ?
note 20 ultra
note 20 ultra
Much easier to turn things on and off without a pc is why it's recommend for ease .I stopped using Package Disabler ever since i learned how to use ADB... A bit more work but ADB always work.
I agree everyone different, just pointing out why package disabler is a more popular optionFor me personally, once i turn an app off. I never enable them again. But again its me xD
How is it compare to PDP ?
Does more then Package Disabler Pro, Also it's free.How is it compare to PDP ?
I know the developer of PDP is not well liked lol
I'll give it a try , thanksDoes more then Package Disabler Pro, Also it's free.
. So Package Disabler doesn't work to block OS updates on 11 - but does on 10? Unfortunately, I didn't have it on my N20U and they pushed the update in the night and I didn't want it. Sure enough, Good Lock doesn't work!!!! My husband hasn't received the update on his A71 and doesn't want it. Can he still install Package disabler to stop any updates? At least until Good Lock works. So mad!Only reason I used package disabler is to block bixby and block OS updates.
The main reason I block OS updates at first is I'm waiting for good lock to update. I'm still on 10, but package disabler isn't working. So Package Disabler doesn't work to block OS updates on 11 - but does on 10? Unfortunately, I didn't have it on my N20U and they pushed the update in the night and I didn't want it. Sure enough, Good Lock doesn't work!!!! My husband hasn't received the update on his A71 and doesn't want it. Can he still install Package disabler to stop any updates? At least until Good Lock works. So mad!
Hahaha, I know right!I'm surprised he hasn't been tarred & feathered by now.
Let us know what you thoughts are on Alliance Shield X after you have tested it!
@Ruben Ocasio, are you using it?
Thanks Gentlemen!
Yes i have been using it for a month already.I'm surprised he hasn't been tarred & feathered by now.
Thanks Gentlemen!
Not to sure you can try it out , it's free so just try it.Is Alliance Shield X only for Samsung phones? What about LG?
Reason is I have both Package Disabler Pro for Samsung and LG. What happened to PDP?
