1. sweetypie31's Avatar
    If I stop Facebook from running in the background will I still get my notifications? I feel like my battery is going down quicker than when I first got the phone and after the Android 11 update. Before I was able to make at least 24 hrs before charging. Now I'm back to charging twice a day.I looked at my battery stats and fb is pretty high.
    I think I've asked this before but for another phone. I just don't remember which one. LolFacebook running in the background-screenshot_20210111-225746_device-20care.jpegFacebook running in the background-screenshot_20210111-230111_gsam-20battery-20monitor-20pro.jpegFacebook running in the background-screenshot_20210111-230138_device-20care.jpegFacebook running in the background-screenshot_20210111-230147_device-20care.jpeg
    Ranjen617 likes this.
    01-12-2021 12:03 AM
  2. TMavC5's Avatar
    Delete the app and start using browser instead.
    01-12-2021 12:14 AM
  3. mustang7757's Avatar
    You can long press facebook app then tap info and restrict background, also force clear it's cache and force close see if it shows up next charge cycle. I gave the app not seeing that kind of battery drain.
    sweetypie31, Ranjen617 and J Dubbs like this.
    01-12-2021 12:21 AM
  4. sweetypie31's Avatar
    Will restricting the background cause me not to get notifications?
    Ranjen617 and mustang7757 like this.
    01-12-2021 12:39 AM
  5. sweetypie31's Avatar
    I can't use the gif option on the browser.
    01-12-2021 12:42 AM
  6. Ranjen617's Avatar
    Your notifications will stop. I've found that fb is the most aggressive app on mine as well. Reopens every time I close it down. I like the app for gifs as well... Their developers could make a much better app without all the drain...😢
    sweetypie31, jimd1050 and J Dubbs like this.
    01-12-2021 03:30 AM
  7. Kizzy Catwoman's Avatar
    This is what I did. I had to disable it though as it wouldn't delete from my S10+
    TMavC5 and J Dubbs like this.
    01-12-2021 08:00 AM
  8. B. Diddy's Avatar
    That really seems like some kind of glitch. I agree with mustang7757 -- try clearing the app cache/data for Facebook, and then force stop it. Then open it again as you normally would, and see if the battery drain comes back over the course of a day.
    mustang7757 and sweetypie31 like this.
    01-12-2021 01:52 PM
  9. mustang7757's Avatar
    It hasn't for me , but try it for a day if it does go back to allowing
    sweetypie31 likes this.
    01-12-2021 02:22 PM
  10. sweetypie31's Avatar
    I ended up turning the background back on last night. I'm going to charge up my phone this morning and see how it does today.
    I do think the cache erase and force close helped because fb isn't as high as it was when I first posted.
    B. Diddy likes this.
    01-13-2021 08:02 AM
  11. sweetypie31's Avatar
    Ok so on Wednesday I tried using my phone with my Facebook app running in the background and yesterday I ran the phone without background. I used the phone and fb app more yesterday than I did Wednesday. I know my usage makes a difference. I'm just trying to see if my battery stats look OK. First pic I'd with background usage. Second is without. Facebook running in the background-screenshot_20210114-072940_device-20care.jpegFacebook running in the background-screenshot_20210115-025545_device-20care.jpeg
    Yesterday 04:06 AM
  1. (Opinion) Would you consider the Pixel 5 a downgrade from Note 10+?
    By blackhawksfan75 in forum Google Pixel 5
    Last Post: Today, 01:23 PM
  2. how do I root my oppo phone? (I have unlocked the bootloader)
    Last Post: 01-11-2021, 09:18 PM
  3. By mistake, I merged the contacts on my Samsung A11 phone. How do I reverse that?
    Last Post: 01-11-2021, 07:07 PM
  4. Replies: 2
    Last Post: 01-11-2021, 03:19 PM
  5. Why doesn't the Cycling exercise on Samsung Health record heart rate while connected to Active2?
    By Android Central Question in forum Samsung Galaxy Watch Active 2
    Last Post: 01-11-2021, 02:47 PM
