1. williams448's Avatar
    After the A11 OneUI3 update on my At&t N20U, sometimes I have touchscreen issues, like...sometimes swiping notifications the notification won't swipe down or will only swipe down half way. Or random times I've gone to touch the screen to select something and it doesn't register my touch. It's random and doesn't happen all the time, just enough for me to notice.
    In the grand scheme of things it's not a big deal, just curious if anyone else has had any issues since the update. I've restarted, cleared cache and it still happens.
    01-14-2021 05:43 PM
  2. Kizzy Catwoman's Avatar
    Hi. O had that issue on S10+ beta 1. Luckily the next beta fixed it for me. So I don't know if that is still an issue on phones that already updated to stable.
    01-14-2021 08:02 PM
  3. mustang7757's Avatar
    In Samsung members app it has a diagnostic tool to check touch interactions, you using screen protector? If so is touch sensitivity on?
    01-14-2021 08:21 PM
  4. williams448's Avatar
    Ha! It was off. I know it was on before the update because I returned it on when I installed my screen protector. Either way...I just turned it back on. I'll keep an eye on it, thanks.
    mustang7757 likes this.
    01-14-2021 10:34 PM
  5. mustang7757's Avatar
    Your welcome, keep us posted
    01-14-2021 10:37 PM
  1. Audible widget issues on samsung
    By kanyon40 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 06-18-2021, 09:52 AM
  2. Update issue
    By Chabidiah07 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 01-21-2021, 09:27 PM
  3. S20 fe 5g wifi issues
    Last Post: 01-16-2021, 02:53 AM
  4. Samsung Galaxy a50u touch screen stopped working after update install
    Last Post: 01-14-2021, 03:41 PM
  5. Audible widget issues on samsung
    By kanyon40 in forum Android Apps
    Last Post: 01-14-2021, 12:28 AM
