1. Leec4's Avatar
    Up to 2 weeks ago, I've had no problem with bluetooth connection for my car.
    All of a sudden, it now takes probably 3 minutes after I've turned my car on for my phone to fully connect. (Which is fine I guess)
    What is happening now that it only connects with calls and no audio. When I go to my Bluetooth settings the audio tab is grayed out indicating that it is no longer an option. I have tried unpairing and repairing my Bluetooth with no resolution. not sure what has changed in the last couple weeks when it was working.
    Anyone have any ideas?
    01-29-2021 01:44 PM
  2. sonnnet's Avatar
    Have you tried connecting to a different Bluetooth device, eg Bluetooth headphones? If so, does that work as it should?
    01-29-2021 04:06 PM
  3. sonnnet's Avatar
    Also, when you say you have unpaired and repaired, did you do this on the phone or the car? Try doing both. My car is usually fine but on the occasions I've had issues, on the car, I've gone into the Bluetooth settings and deleted the phone as a device. Then deleted pairing on phone. Then repair. It might help the car to send the required permission requests over to the phone again (calls and audio).
    01-29-2021 04:15 PM
  1. Why doesn't my games work correctly on my note 20 ultra
    By Android Central Question in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 02-11-2021, 11:14 AM
  2. GCam for note 10+?
    By srgonu in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 02-09-2021, 12:52 AM
  3. After Android 11 update, can no longer send/receive texts while on call
    By Jim Nafus in forum Samsung Galaxy S10 & S10+
    Last Post: 01-27-2021, 03:40 PM
  4. Why doesn't my games work correctly on my note 20 ultra
    Last Post: 01-27-2021, 03:03 PM
