1. Mike Heppe's Avatar
    Howdy folks
    So lost an iPhone a couple days ago. I decided to go back to the note 20 which I had about six months ago. My new note was set up at the Verizon store by the guy. So I was not really involved with the initial set up. Since I previously owned a note 20 shouldn't I be able to restore my previous settings and whatnot?
    Thanks a bunch
    04-11-2021 07:21 PM
  2. mustang7757's Avatar
    Hi, if you did a back up through smart switch , Google photos, Samsung cloud which is limited now what it backs up but settings definitely.
    04-11-2021 09:05 PM
  3. bandofbrothers2112's Avatar
    The Samsung Cloud will put your previous settings and backed up information onto your new phone.
    Samsung Cloud does not back up photo's anymore.
    Samsung stopped this and now has advised to use Onedrive.
    04-11-2021 11:36 PM
  4. bandofbrothers2112's Avatar
    04-11-2021 11:36 PM
  5. Kizzy Catwoman's Avatar
    Google may also have done a backup to your account which can be retrieved on setup.
    aximtreo likes this.
    04-12-2021 03:15 AM
  1. Brand new to android phones, help me pick
    Last Post: 04-11-2021, 04:43 AM
  2. Will there be an update on the S21 Ultra front cam?
    By Android Central Question in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 04-11-2021, 03:08 AM
  3. Will there be an update on the S21 Ultra front cam?
    Last Post: 04-11-2021, 01:46 AM
  4. SD card Problem 512GB on Note 9.
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 04-11-2021, 12:41 AM
  5. SD card Problem 512gb on note 9
