1. ODog2323's Avatar
    Does anyone experience notifications on some of their apps getting delivered late? For example, one of my weather apps (Today Weather) will alert me that rain is likely at my location @ 7pm, and that alert won't come until 7:20. The COVID tracking is set to remind me to check in at 8am, but that alert often doesn't come in until up to an hour later.
    I assume this is some sort of battery saving measure which is holding back some background tasks, but I haven't had luck pinning the exact cause yet.
    Or does this device just suck at keeping track of time?? Lol
    04-12-2021 06:26 PM
  2. mustang7757's Avatar
    Hi, check device care any deep sleep apps or sleeping apps?
    04-12-2021 07:45 PM
  3. ODog2323's Avatar
    Hey, yes there are some, but not the ones I'm thinking of. In fact, a little while ago I set a few of the suspect apps to never sleep, but that did not change anything. Many Notifications Delayed, N20 Ultra-screenshot_20210412-205607_settings.jpg
    04-12-2021 07:58 PM
  4. mustang7757's Avatar
    Hey, yes there are some, but not the ones I'm thinking of. In fact, a little while ago I set a few of the suspect apps to never sleep, but that did not change anything. Click image for larger version.
    Thats the stock weather or Google ?
    Because they have refresh rate time based you can adjust
    04-12-2021 08:00 PM
  5. ODog2323's Avatar
    It's Today Weather. The widget refreshes every 30 minutes, but alerts like that should come right through, and have on previous devices.
    Anyway that's just one example same thing happens with some other apps as well.
    04-12-2021 08:06 PM
  6. mustang7757's Avatar
    You use any power save mode ?
    04-12-2021 08:24 PM
  7. ODog2323's Avatar
    Nope, and this happens regardless of the battery level
    04-12-2021 08:32 PM
  8. mustang7757's Avatar
    Have you tried resetting the app by clearing its data then force stop.it?
    04-12-2021 08:44 PM
  9. ODog2323's Avatar
    Just noticed in the battery optimization settings that not only are the apps in question being optimized (which I turned off optimization to see what will happen), but many system apps have this enabled as well. Do I really want Samsung governing things like "Android System" and "System UI"?? Many Notifications Delayed, N20 Ultra-screenshot_20210415-195820.jpg
    04-15-2021 06:58 PM
  10. mustang7757's Avatar
    Just noticed in the battery optimization settings that not only are the apps in question being optimized (which I turned off optimization to see what will happen), but many system apps have this enabled as well. Do I really want Samsung governing things like "Android System" and "System UI"?? Click image for larger version.
    You can disable optimaztion but they do this to save battery as much as possible
    04-15-2021 08:20 PM
  11. ODog2323's Avatar
    I know that. Question is, should some of those deeper system apps be "optimized" or should they be allowed to run as they want?
    04-16-2021 03:33 AM
  12. mustang7757's Avatar
    You have certain system app that can't be controlled or optimized
    04-16-2021 09:07 AM
  1. My new Samsing 31 Ultra 5 phone has no download manager
    Last Post: 04-12-2021, 03:43 PM
  2. New Note 20 Ultra
    By Mike Heppe in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 04-12-2021, 03:15 AM
  3. Is there a way to prevent notifications being swiped in the lockscreen?
    By Anson Tung in forum General Help and How To
    Last Post: 04-11-2021, 12:23 PM
  4. Why is my notification bar and recents button not working?!
    Last Post: 04-11-2021, 11:26 AM
  5. Will there be an update on the S21 Ultra front cam?
    By Android Central Question in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 04-11-2021, 03:08 AM
