1. jasqid's Avatar
    I need some help deciding on which phone to "upgrade" to. I am looking at the (T-Mobile) Note 20 and the S21 Plus. They are the same price. I am not all too interested in the intricacies in specs between the two. They seem pretty close, or at least close enough for me. My daughter just got her first droid phone, s21. It seems really nice, just a little small for me comparing it to my current LG V40. So I was looking at the plus with the larger screen. Then I noticed the Note 20 having the same price point. They seem similar in size that I would be comfortable with. I am undecided between the two. The stylus would be nice but I am not sure how much I would use that. I am a small business owner and very settled in Office (Microsoft) 365. I noticed the Samsung devices have better.... integration if you will. i.e. your Phone / PC experience.
    I want to clarify my "spec" comment above.... I am not too bothered about which camera is better, or the 120hz screen refresh rate , fastest processor etc... Compared to what I have now, either is going to be a nice jump. I seem to be stuck on the matching price and if perhaps I should flip a coin on it. Or maybe I do want the Note for the stylus to sign an application/form on the fly. uggg. LOL. I guess ultimately I'm looking for a little perspective from anyone that was on the same fence. - Thanks for your time reading this mess!!
    04-19-2021 03:37 PM
  2. D.P.G.'s Avatar
    Do you like round corners or more of a rectangle. Personally I feel the display on the Note 20 Ultra appears sharper with better color. I would choose the Note 20 Ultra and once you start using the SPen it becomes more useful then one may think.
    04-19-2021 05:50 PM
  3. Robert Sisson's Avatar
    I own the Note 20 Ultra 5g. It's an incredible phone. The camera just got another upgrade and is excellent. However, I believe the key is that your a business owner. The Note with built in stylus was built for business folks. I have found the spen, over my years of practicing law, to be more help than I ever imagined. Go with the Note. You'll be glad you did.
    04-19-2021 07:44 PM
  4. o4liberty's Avatar
    I have the regular note 20 ok tmobile and it's a Fabolous device no issues at all. Best device to date for me.
    04-19-2021 09:34 PM
  5. jasqid's Avatar
    Hey, thanks for your feedback guys. I appreciate your input. I just happen to have found a video review after my initial post and the one thing I came away with from his video was the s21s are more likely to have another year of updates and support compared to the 20. Even with that said I think I'm leaning towards the note 20.
    aximtreo likes this.
    04-19-2021 10:01 PM
  6. bandofbrothers2112's Avatar
    I'd suggest to visit a Highstreet Store when they re open to have hands on with both models.
    I leaned towards the N20 Ultra 5G because I do use the stylus often.
    That said the s21 has stylus support too.
    I did import my N20 Ultra 5G into the UK because I wanted the Snapdragon version as it in my opinion is a more powerful phone than the variant with the Exynos soc in it.
    Enjoy the journey.
    04-19-2021 11:04 PM
  7. Deimos10's Avatar
    If it comes down to the S-pen it's Note all the way. Integrated and always available, with Bluetooth capabilities. No contest.
    aximtreo and Alan Sims like this.
    04-21-2021 08:39 AM
  8. L0n3N1nja's Avatar
    I'd go with the Note, they are very similar phones but I'd want the stylus. I've used the Note series for years and although I don't use the S Pen daily I miss it when I use a phone without it.
    JHStewart1023 likes this.
    04-21-2021 10:13 AM
  9. gray2018's Avatar
    Note 20 Ultra. S-Pen, Expandable storage and actually comes with a charger in the box. That's a no brainer for me. If none of that bothers you, go with the S21 plus as I believe it's a bit cheaper.
    Alan Sims likes this.
    04-21-2021 10:20 AM
  10. jasqid's Avatar
    Well.... I purchased the Note 20 Ultra. 2 of them. One for me and one for the wife.
    04-30-2021 06:18 PM
  11. JHStewart1023's Avatar
    Good choice! It was the one I'd recommend. It has expendable memory, and in my opinion has the better camera set up and battery life over the 21plus. ❤
    mustang7757 and aximtreo like this.
    05-05-2021 03:46 AM
  1. How is the S21?
    By gray2018 in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 05-06-2021, 02:40 PM
  2. Note 9 Gallery Settings
    By RobertFCda in forum Samsung Galaxy Note 9
    Last Post: 04-19-2021, 09:29 PM
  3. Iam unable to disable assistive touch on my lg q7 plus phone
    Last Post: 04-19-2021, 05:12 PM
  4. Galaxy S21 Calendar Sync
    By Litch in forum Ask a Question
    Last Post: 04-19-2021, 05:10 PM
  5. Does the Galaxy S21 Ultra support dual SIM or not?
    By TeknoBlast in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 04-19-2021, 12:23 PM
