1. Bildriver's Avatar
    Has anyone found screen protection that allows the fingerprint sensor to function correctly????
    06-30-2021 02:56 PM
  2. mustang7757's Avatar
    I only use White Stone Dome glass protector , any of the film should work
    Morty2264 likes this.
    06-30-2021 03:00 PM
  3. sweetypie31's Avatar
    Right now I'm using ringke dual easy wings film protector. The fps has been working fine for me.
    mustang7757 likes this.
    06-30-2021 03:51 PM
  4. donm527's Avatar
    Spigen NeoFlex plastic screen protector.
    Just took a picture of it… installed it when I got the phone at launch… 11 months already??… and haven’t had a need to put a fresh one on it yet. I must have gotten lucky on the application… not a lift anywhere and no build up of debris and I’ve been pocket carrying this phone from day one.
    FPS hasn’t been an issue this whole time. And I like it because it’s super thin and clarity hasn’t been an issue.
    Attached Thumbnails Note 20 screen protection/finger print sensor.-e562f347-a317-4f85-aaeb-8d730b6a2fec.jpg
    Kizzy Catwoman and aximtreo like this.
    06-30-2021 10:42 PM
  5. bandofbrothers2112's Avatar
    I also use the Whitestone Dome Glass Screen Protector.
    Just ensure the factory fitted screen protector is removed before fitting the new one.
    07-01-2021 12:08 AM
  6. Morty2264's Avatar
    I've had luck with Skinomi screen protectors on my S10, too!
    07-01-2021 10:38 AM
  7. Bildriver's Avatar
    Thank you everyone. That what I like about the forums.
    07-01-2021 10:42 PM
  1. How do I put finger print on screen without a PIN?
    Last Post: 06-30-2021, 07:55 AM
  2. How to remove the number to the screen home page
    Last Post: 06-29-2021, 12:08 PM
  3. Replies: 1
    Last Post: 06-28-2021, 04:33 PM
  4. Samsung Galaxy S20 Note How do I snap a picture of a document on my phone?
    Last Post: 06-28-2021, 01:08 PM
  5. Note 10 Plus pro camera mode
    By gray2018 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 06-28-2021, 11:21 AM
