Save big + get 3 months free! Sign up for ExpressVPN today
08-04-2021 06:14 AM
32 12
tools
    On my other phone I used gboard and I had the ability to push the microphone to do voice to text or I could hold it in and do a voice recorded message that would then send to whoever was on my screen for a message and they would be able to listen to my voice recorded message. I am no longer able to do that on my new 1 ultra 5G note 20 and I don't know why and I would like to know what I need to do to enable that to make it happen. Just to clarify yes I have a microphone yes it works perfectly for talk to text it is no longer recording a voice message to be played by a 1
    08-01-2021 12:26 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you using Samsung Messages? If so, then do you see the Voice Message icon at the lower right, next to the text entry field? It looks like a bunch of vertical lines from a spectrum analyzer. Long-press that, and it should prompt you to record your voice message. I circled it in this image:
    I am unable to record a voice message from my keyboard on my Samsung Android Note 20 ultra 5G-screenshot_20210801-103308_messages.jpg
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    mustang7757 and AnnDroid like this.
    08-01-2021 12:32 PM
  3. mustang7757's Avatar
    You don't see the microphone in the text field?
    I am unable to record a voice message from my keyboard on my Samsung Android Note 20 ultra 5G-screenshot_20210801-135138_messages.jpg
    MaidUp13 likes this.
    08-01-2021 12:53 PM
  4. MaidUp13's Avatar
    Course I see the microphone did you guys read my message to verify it does talk to text just fine with the microphone but the microphone doesn't allow me to record the message to be played back by a receiver yes I have a microphone no I'm not using Samsung I'm using gboard I said all this in my message
    08-01-2021 12:57 PM
  5. B. Diddy's Avatar
    Did you look at my screenshot? To record a voice message, don't use the microphone associated with the keyboard app. Long-press the icon to the right of the text entry field of the Messages app.
    J Dubbs likes this.
    08-01-2021 01:05 PM
  6. mustang7757's Avatar
    As you can see from screen shot I'm using Gboard and there are 2 microphone the one I pointed to is for voice message, if it's not working then clear data and force stop your message app.
    08-01-2021 01:29 PM
  7. B. Diddy's Avatar
    To clarify -- the mic icon you're pointing to is for the Voice Message function for the Google Messages app, not Samsung Messages. So the OP needs to clarify which messaging app they're using (I was assuming it was Samsung Messages, which is the screenshot I shared).
    mustang7757 likes this.
    08-01-2021 01:34 PM
  8. mustang7757's Avatar
    Yeah sorry I'm using the Google/Samsung collaboration app that come in newer Samsung device. But what I mentioned clear data and force stop the message app still applies if the voice record is not working.
    08-01-2021 01:37 PM
  9. B. Diddy's Avatar
    Yep, and we need to make sure there's no confusion between the mic icon that's part of the Gboard app, and the mic icon (or that spectrum analyzer icon in the Samsung Messages app) in the messaging app that's specifically for the voice message feature.
    08-01-2021 01:41 PM
  10. mustang7757's Avatar
    Correct
    08-01-2021 01:42 PM
  11. mustang7757's Avatar
    This a screenshot on the stock Samsung message app, the message app is responsible for the voice record so if not working long press the message app icon then tap info and scroll to storage clear data and force stop the app I am unable to record a voice message from my keyboard on my Samsung Android Note 20 ultra 5G-screenshot_20210801-144308_messages.jpg
    B. Diddy likes this.
    08-01-2021 01:45 PM
  12. MaidUp13's Avatar
    Yes I saw it and that's for Samsung keyboard I use Google gboard it's different
    But if I'm not using Samsung and I'm only using gboard what does it make a difference to do anything to the Samsung app I'm not using it
    I mean I'm not the most technically inclined obviously. But it seems to me if I'm not using an app why would I need to fix it to make the other app work it doesn't make sense to me so please explain
    08-01-2021 05:49 PM
  13. mustang7757's Avatar
    Doesn't matter which keyboard your using, it the message app so clear it's data and force stop it.
    08-01-2021 06:11 PM
  14. B. Diddy's Avatar
    Let's make sure we'll all on the same page here. Do you see the icon we're pointing out in our screenshots? If so, do you have that icon on your messaging app? Show us a screenshot so we can see.
    08-01-2021 06:22 PM
  15. MaidUp13's Avatar
    Thank you
    I will try to force stop
    With all due respect.. the image, from what I see, doesn't give need a clue which keyboard it is. I can not tell them apart. And my confusion, apologies, the other member specifically asked about Samsung and sent Samsung image. Sorry.
    I'm unable to screenshot when I have keyboard in view. I use palm swipe to capture. If there's another way to screenshot least let me know
    08-02-2021 06:02 AM
  16. MaidUp13's Avatar
    I cleared data. I forced stop. I even uninstalled and reinstalled. And it's still isn't working except for talk to text. I just don't understand why I'm having so many problems with such a brand new phone I had no problems with my note 9 I should kept it so frustrating
    Who might somebody I can go to locally that is smart about phones that can check my phone out thoroughly and find out what the hell's going on with it cuz Verizon doesn't help they don't really do much I've been down there a few times
    08-02-2021 06:11 AM
  17. mustang7757's Avatar
    You can hold power and volume down simultaneously there are other ways also but stick to this for now
    The stock message app you can't uninstall, so can you show me which message app you have by screenshot the icon ?
    08-02-2021 09:04 AM
  18. mustang7757's Avatar
    You can go to youbreakitifix they certified Samsung repair shop , Samsung experience store can also help , best buy maybe one of their phone people can assist.
    08-02-2021 09:07 AM
  19. MaidUp13's Avatar
    I'm still using gboard
    I did this it's still not working
    I don't understand I've mentioned like four or five times Google Google keyboard gboard gboard I don't understand
    Attached Thumbnails I am unable to record a voice message from my keyboard on my Samsung Android Note 20 ultra 5G-screenshot_20210802-114615_chrome.jpg
    08-02-2021 10:49 AM
  20. mustang7757's Avatar
    Which out of the 3 here are you using for message app?I am unable to record a voice message from my keyboard on my Samsung Android Note 20 ultra 5G-screenshot_20210802-115352_nova7.jpgI am unable to record a voice message from my keyboard on my Samsung Android Note 20 ultra 5G-screenshot_20210802-115344_google-20play-20store.jpg
    08-02-2021 10:54 AM
  21. mustang7757's Avatar
    You have to relax , I know it's frustrating but when this is done over a forum we have to make sure we on the same page , if it was in person be totally different.
    08-02-2021 10:57 AM
  22. MaidUp13's Avatar
    Yeah it's frustrating I don't know why it has to be repeated several times to the same people honestly you have to read
    I'll ask for forgiveness but please read I mean I'm having so much issues with this brand new phone all of a sudden and I don't get it I just don't get it the volume doesn't work right doesn't matter if it's Bluetooth or not speaker or phone media volume it doesn't matter it's sometimes it's loud sometimes it's not and I don't do anything to adjust it it just randomly goes up and down. I'm having issues with the keyboard not only can I not do the recording an audio message but when I do do talk to text it never wants to record the first word that I say I have to go back and add it then the whole sticker Center garbage I'm going to just it's this is a brand new phone you're right I'm frustrated had it a few months and it's acting worse than my note 9 that I had for 2 years
    08-02-2021 11:03 AM
  23. Post Nine's Avatar
    uninstall gboard and reinstall it, both voice to text and press and hold to record a message work on mine.
    08-02-2021 11:49 AM
  24. mustang7757's Avatar
    Which message app your using ?
    Your keyboard dictate the voice to text features, your message apps does the voice record .
    Go to settings>general mamgement>make sure everything there is Google , also clear data and force stop your Gboard
    08-02-2021 01:18 PM
  25. B. Diddy's Avatar
    Thank you
    Once again, here's the screenshot I posted for the Samsung Messages app, because I assume you're using the Samsung Messages app to try to record a Voice Message, correct?
    Look at the lower right. Do you see that icon that's circled? It looks like a bunch of squiggly lines. That's what you have to long-press (not short-tap, but long-press) in order to record a Voice Message that then gets sent via the text message app to the recipient, who can then play it on their text messaging app. Do not use the microphone icon that is part of the keyboard. That is for dictation only, and will transcribe anything you say into text. I did not include a screenshot of the keyboard in that image because you don't need the keyboard to record a Voice Message.
    Please let me know if this is not clear.
    sweetypie31 likes this.
    08-02-2021 11:15 PM
32 12
  1. Replies: 10
    Last Post: 08-03-2021, 02:27 PM
  2. Samsung Cloud to One Drive work around?
    By T48 in forum Samsung Galaxy Note 9
    Last Post: 08-01-2021, 07:40 PM
  3. samsung galaxy note 9+ Quick start guide hunt
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 08-01-2021, 11:57 AM
  4. Kann ich Google Play Spiele auf meinem Samsung Galaxy Book S spielen?
    Last Post: 08-01-2021, 11:49 AM
  5. samsung galaxy note 9+ Quick start guide hunt
    Last Post: 08-01-2021, 09:49 AM
