1. Carrie Greicar's Avatar
    So I was trying to set individual notification tones for a couple of apps and would like to shut off the sound for the rest but I don't have the option in the notifications. Did that go away? (I had switched to some for a while so haven't been with Samsung for a while)
    Thanks in advanceAttachment 335800Sound setting for app notifications missing-screenshot_20210809-125438_settings.jpg
    08-09-2021 02:08 PM
  2. mustang7757's Avatar
    Yeah the notifications you change in your screen shot is global, if you want different tone for individual apps long press that app>tap info>notification>tap each category to get submenu to change it.
    08-09-2021 02:14 PM
  3. Carrie Greicar's Avatar
    Thanks it's not giving me that option. The first screen shot I added is what options in seeing when I long press the app
    08-09-2021 02:17 PM
  4. Carrie Greicar's Avatar
    Oops this is what I see and when I click on notifications it just toggles it offSound setting for app notifications missing-screenshot_20210809-125312_settings.jpg
    08-09-2021 02:35 PM
  5. mustang7757's Avatar
    Oops this is what I see and when I click on notifications it just toggles it offClick image for larger version.
    Tap notification in screen shot
    08-09-2021 02:38 PM
  6. Carrie Greicar's Avatar
    This is what I get when I tap notifications in the screen shotSound setting for app notifications missing-screenshot_20210809-133945_settings.jpg
    08-09-2021 02:40 PM
  7. Carrie Greicar's Avatar
    And when I tap the show notifications it just toggles it off
    08-09-2021 02:40 PM
  8. mustang7757's Avatar
    Ok so that one you cant change
    This example on my message app Sound setting for app notifications missing-screenshot_20210809-143750_settings.jpg
    08-09-2021 02:45 PM
  9. mustang7757's Avatar
    Try go in that app settings to see anything can be changed
    08-09-2021 02:46 PM
  10. Carrie Greicar's Avatar
    Well darn. I don't have that on any of my apps
    08-09-2021 02:54 PM
  11. mustang7757's Avatar
    Yeah some apps wont allow changes
    08-09-2021 02:57 PM
  12. Carrie Greicar's Avatar
    Dumb question do you know if the android Central app allowed the changes? I might have to call Samsung because I don't have the option there either
    08-09-2021 02:59 PM
  13. mustang7757's Avatar
    I use the forums app but i can download that one and check
    08-09-2021 03:06 PM
  14. Carrie Greicar's Avatar
    You are awesome for checking. Thanks so much
    mustang7757 likes this.
    08-09-2021 03:07 PM
  15. Carrie Greicar's Avatar
    My message app isn't even giving me the option
    08-09-2021 03:07 PM
  16. mustang7757's Avatar
    Android central app doesn't eitherSound setting for app notifications missing-screenshot_20210809-150809_android-20central.jpgSound setting for app notifications missing-screenshot_20210809-150724_settings.jpg
    08-09-2021 03:08 PM
  17. mustang7757's Avatar
    AC forum apps does , in my opinion much better then AC app which is limited.Sound setting for app notifications missing-screenshot_20210809-150931_settings.jpg
    08-09-2021 03:10 PM
  18. Carrie Greicar's Avatar
    Thanks for checking
    08-09-2021 03:10 PM
  19. mustang7757's Avatar
    Thanks for checking
    Welcome
    08-09-2021 03:11 PM
  20. Seeker336's Avatar
    Did you try to access the settings this way?
    Pull down your shade from the top. Press the gear icon in the top right corner. Third category down should be NOTIFICATIONS. Tap that category, next screen should show "recently sent." It will display the last three or so apps to send a notification. Just below should be "More." Tap More and you should get a screen that shows a list of apps that send notifications. Open each and you will get a list of the type of notification the app will send.Open that and you will get "Alert" or "Silent" -- if you select "Alert", you can then select "Sound" to define the sound that will be triggered for that specific notification in that specific app.
    Hope that helps. Cheers
    08-09-2021 03:15 PM
  1. Can't turn off underlining for words typed
    Last Post: 12-29-2021, 02:43 AM
  2. Replies: 11
    Last Post: 08-14-2021, 07:24 AM
  3. Apps on my mobile are showing refresh symbol
    Last Post: 08-09-2021, 02:20 PM
  4. Which Android SYSTEMS app controls internet content?
    By Gob Shite in forum Android Apps
    Last Post: 08-09-2021, 12:43 PM
