1. dlgus's Avatar
    This post took for BLEEPING ever to write because my stylus appears SERIOUSLY uncalibrated.
    Is there a way to fix this?
    09-17-2021 04:49 PM
  2. IslandGuy's Avatar
    Try the Samsung Members app. Under the get help tab, run diagnostics on the S-pen.
    BergerKing likes this.
    09-17-2021 05:43 PM
  3. mustang7757's Avatar
    Try resetting the spen in settings>advanced features>spen tap>tap air actions>3 dots upper right corner tap then choose resetStylus seems out of calibration, how do I fix it?-screenshot_20210917-222606_air-20command.jpg
    09-17-2021 09:27 PM
  4. dlgus's Avatar
    Try resetting the spen in settings>advanced features>spen tap>tap air actions>3 dots upper right corner tap then choose resetClick image for larger version.
    Thank you SO much! I think that did the trick!
    mustang7757 likes this.
    09-26-2021 06:18 PM
  5. mustang7757's Avatar
    Your welcome , glad to help
    09-26-2021 06:28 PM
  1. [Solved]Google Assistant seems to be down.
    By Smokeaire01 in forum Android Apps
    Last Post: 09-18-2021, 09:34 AM
  2. my phone is flickering after it got dunked on the flood
    Last Post: 09-17-2021, 10:00 PM
  3. Samsung S20 screen pattern locked out...
    Last Post: 09-17-2021, 09:22 PM
  4. Why are the comments on AndroidCentral about how Windows and Mac OS work?
    By Illilillili Fernhaven in forum Site Feedback & Help
    Last Post: 09-17-2021, 07:19 PM
  5. Why are the comments on AndroidCentral about how Windows and Mac OS work?
    By Illilillili Fernhaven in forum Ask a Question
    Last Post: 09-17-2021, 03:10 PM
