1. Borgie's Avatar
    Pretty sure I have all the settings correct. have it turned on for all apps. I know it works for at least 1 as when my door locks or unlocks with the schlage it the edge lighting works on the notification.
    It worked fine on everything on the s20 ultra.
    Does Edge lighting only work for some apps?-screenshot_20210918-130407_settings.jpg
    Does Edge lighting only work for some apps?-screenshot_20210918-130419_one-ui-home.jpg
    09-18-2021 01:10 PM
  2. neo999's Avatar
    I've noticed the same. My edge lighting settings are similar to yours. But the MLB app is one app that doesn't use edge lighting. It does work on others though.
    09-18-2021 01:50 PM
  3. Borgie's Avatar
    Yeah mine doesn't work for either gmail or bluemail, doesn't work for messages.. i don't know what the hell
    09-18-2021 04:43 PM
  4. RAvEcREAToR23's Avatar
    Hello i use this epic app you try too (arround camera light ring as get notifications)
    https://play.google.com/store/apps/d...lwaysondisplay
    09-19-2021 09:22 AM
  5. drewood31601's Avatar
    You have to have the app that you want to show edge lighting set to show as a pop-up in order for edge lighting to work.
    09-20-2021 11:14 AM
  6. Borgie's Avatar
    I have notifications set to all apps. I get actual notifications from gmail, bluemail, messages etc.... just no edge lighting for them
    09-20-2021 06:39 PM
  7. drewood31601's Avatar
    Make sure that the app you want to show edge lighting is set to "show as pop up"...that's found in the notification settings for the individual app, not the system notifications setting.
    BerryBubbles likes this.
    09-21-2021 04:43 PM
  8. BerryBubbles's Avatar
    That definitely made a difference for a few of mine that didn't alert with edge lighting. Thank You!
    Now if I could only get Gmail to notify in any form. No sound, vibration or badges. Maneuvering through the Gmail settings is like negotiating a maze. One wrong click & your are back to where you started.
    09-30-2021 06:07 PM
  1. Delay in shipments for Z Fold 3s?
    By Android Central Question in forum Samsung Galaxy Z Fold 3
    Last Post: 10-13-2021, 08:47 AM
  2. Z Flip³ Weight... So light!
    By tadpoles in forum Samsung Galaxy Z Flip 3
    Last Post: 09-23-2021, 05:34 PM
  3. Delay in shipments for Z Fold 3s?
    By Android Central Question in forum Samsung Galaxy Z Flip 3
    Last Post: 09-21-2021, 07:46 PM
  4. Delay in shipments for Z Fold 3s?
