2 Attachment(s)
AT&T Note20 Ultra 5G 512GB November Patch
AT&T Note20 Ultra 5G 512GB Snapdragon, November Patch Rolling out live . Firmware N986USQS2DUJA
Attachment 339063Attachment 339064
Re: AT&T Note20 Ultra 5G 512GB November Patch
Just woke up to mine needing to be installed.
Installed this update last night and immediately had connection issues. Had to run Good Guardian to clean memory and apps then the issue seem to have gone away.
Originally Posted by
sweetypie31 Just woke up to mine needing to be installed.
Same here. Installing.
Ruben Ocasio That is so cool how you put a photo on your software screen!
IslandGuy Installed this update last night and immediately had connection issues. Had to run Good Guardian to clean memory and apps then the issue seem to have gone away.
What is good guardian? I can't find it on Google play
ansa82 What is good guardian? I can't find it on Google play
Its in the Galaxy store , battery save features
mustang7757 Its in the Galaxy store , battery save features
Thanks!!
1 Attachment(s)
kixfan That is so cool how you put a photo on your software screen!
Hex Pro , i just changed it again, with Hex Pro you get to customize the whole phone the way you want can pick colors, icon, custom quick settings etc etc.Attachment 339148
Ruben Ocasio Hex Pro , i just changed it again, with Hex Pro you get to customize the whole phone the way you want can pick colors, icon, custom quick settings etc etc.
Attachment 339148 Is that an app? All I saw in the play store was a game called Hex Pro.
1 Attachment(s)
kixfan Is that an app? All I saw in the play store was a game called Hex Pro.
Yes it's and app .Attachment 339152
Ruben Ocasio Downloaded it. Now I have to wait to get home to play with it. Need by PC for ADB.
kixfan Downloaded it. Now I have to wait to get home to play with it. Need by PC for ADB.
You will need plugins , plugins are what themes it with Hex and to activate Hex Pro in Hex Settings need to click on donation.
1 Attachment(s)
If you are unfamiliar with ADB like I was, use the browser option. It's super easy. Attachment 339156
IslandGuy If you are unfamiliar with ADB like I was, use the browser option. It's super easy.
Attachment 339156 I ended up using the non pc method using Shizuku. Works great but now I have no idea what I'm doing. Lol
kixfan I ended up using the non pc method using Shizuku. Works great but now I have no idea what I'm doing. Lol
It's a learning process. I'm still learning myself.
