01-20-2022 09:57 AM
52 123
tools
  1. TechNut79's Avatar
    Samsung global goals ? Refresh my memory on that
    You get paid to see ads and then you donate that to different goals like food security and other things around the world.
    mustang7757 likes this.
    01-13-2022 12:00 PM
  2. mustang7757's Avatar
    Ok remember seeing that
    01-13-2022 12:09 PM
  3. TechNut79's Avatar
    And now I'm getting notifications for the same email over and over and over...
    01-13-2022 12:18 PM
  4. mustang7757's Avatar
    Maybe disable goals see if everything returns normal
    TechNut79 likes this.
    01-13-2022 12:27 PM
  5. TechNut79's Avatar
    That fixed it. I guess I'll leave it turned off for now. Now to figure out why my email notifications keep coming for the same email.
    01-13-2022 12:34 PM
  6. mustang7757's Avatar
    Good
    That one going be tricky on lock screen
    01-13-2022 12:54 PM
  7. TechNut79's Avatar
    That one is just in general, not even just on the lock screen.
    01-13-2022 01:06 PM
  8. mustang7757's Avatar
    Force stop that email app and see next notification
    01-13-2022 01:21 PM
  9. TechNut79's Avatar
    OK, we'll see.
    01-13-2022 01:23 PM
  10. mustang7757's Avatar
    01-13-2022 01:36 PM
  11. awl_bidness's Avatar
    With Android 12 update (and UI 4.0), I am finding all the notifications I had set to silent now have permission to alert with sound. A major pain, because many of these apps break down notification permissions into subcategories so every one must be reset.
    01-14-2022 08:03 PM
  12. mustang7757's Avatar
    Not fun
    01-14-2022 09:25 PM
  13. fritomisto's Avatar
    I am being forced to update to Android 12 and I really don't want to until the bugs have been worked out of it. I have read too many bad reviews. Unfortunately I only have 9 delays left that I can push it forward, as I don't see, and haven't found any way to stop the process. So question 1 is, does anyone know how to stop the forced updated once its being pushed along?
    Second question. I have always removed, or at least unmounted my sd card as a precaution when updating my phones, in case of accidental deletion, which has happened to me in the past. Does anyone else do this, and is it still recommended or not?
    Thanks
    01-15-2022 01:23 AM
  14. mustang7757's Avatar
    Thanks
    Yeah it's best to safely unmount just in case .
    BerryBubbles and fritomisto like this.
    01-15-2022 01:39 AM
  15. BerryBubbles's Avatar
    Thanks
    Hi, as far as your second question, I still remove my SD card on major updates. I'm not sure if it's recommended as it once was, but I like to live by "Better Safe Than Sorry". If you store the ringtones & notification sounds on your SD card you may have to set them up again. I finally had enough of that nonsense & I moved all my ringtones & notification media to the internal designated folders.
    fritomisto likes this.
    01-15-2022 01:46 AM
  16. fritomisto's Avatar
    Thanks for confirming that I'm not alone in my old school approach.
    Any thoughts on stopping the countdown to installing Android 12?
    BerryBubbles likes this.
    01-15-2022 09:33 AM
  17. mustang7757's Avatar
    To stop the Android 12 you have 2 choices
    https://www.packagedisabler.com/ which is paid app and my personal favorite or free in the play store Alliance shield X
    01-15-2022 09:54 AM
  18. fritomisto's Avatar
    Does it stop it while it's in mid countdown? And will I need to go into software settings, because I can't go into my software update setting because it just forces the move along .
    01-15-2022 10:00 AM
  19. mustang7757's Avatar
    It stops all OTA software updates until you enable again
    01-15-2022 10:07 AM
  20. fritomisto's Avatar
    @mustang7757 what is your opinion of Android 12 and one UI4?
    01-15-2022 10:17 AM
  21. mustang7757's Avatar
    Im liking some UI improvement , different settings but overall pretty good.
    debdroid1a likes this.
    01-15-2022 10:28 AM
  22. ladiinay's Avatar
    Only issue I have found is the change from Link Sharing to Quick Share. It seems like it doesn't actually create a link which is strange. It says to scan a qr code for the link. I used link sharing to share videos through text messages. So how ???
    01-15-2022 10:43 AM
  23. fritomisto's Avatar
    I read some scathing critiques about it feeling like it was made to feel "less professional ", and that many things were reorganized into different categories and settings than where they have been, making it a hassle to find if you've been used to A11
    01-15-2022 10:54 AM
  24. fritomisto's Avatar
    Also, I never have understood why they remove some really cool functions, like many old camera functions they had way back on the Note 3 and such like the golf swing shot
    01-15-2022 10:58 AM
  25. trucksmoveamerica#AC's Avatar
    Click where I circled and it will create a link. Then you choose which app you want to use to share it. Basically they created extra steps to do the same thing.. Progress in the works
    01-15-2022 12:29 PM
52 123
  1. Samsung Keyboard Glitch after updatiing to Android 12.
    By bandofbrothers2112 in forum Samsung Galaxy Z Fold 3
    Last Post: Yesterday, 01:28 AM
  2. Microphone with bluetooth hooked up to my phone i need history
    Last Post: 01-07-2022, 02:05 PM
  3. Can I uninstall android orio
    Last Post: 01-07-2022, 11:49 AM
  4. S20 Ultra - SMS Link Preview wont work anymore
    Last Post: 01-06-2022, 06:00 PM
  5. Reloading the recovery partition on an Ares 8A NX16A8116KP tablet
    Last Post: 01-06-2022, 05:58 PM
