1. kgilbertsen's Avatar
    Note 20 Ultra.
    I've been getting this a lot in the last few days...
    'Your phone's not registered on a network, so you can only make emergency calls.'
    I restart and things are fine for a time. Probably happens twice a day or more. Seems like a sim card issue. No apparent problem with it. Are there issues with this phone??
    06-28-2022 11:36 AM
  2. mustang7757's Avatar
    06-28-2022 11:39 AM
  3. mustang7757's Avatar
    You can try resetting network in settings>general management>reset>reset network
    06-28-2022 11:39 AM
  4. kgilbertsen's Avatar
    How old your sim card?
    Not quite a year. I think 11 mos into a 24 month deal.
    06-28-2022 11:52 AM
  5. mustang7757's Avatar
    Try the network reset see what happens
    06-28-2022 11:53 AM
  6. kgilbertsen's Avatar
    Did this. Then realized I'll need to re-learn ALL the wifi settings for family & friends... oh well. Hope it is the fix - thanks.
    mustang7757 likes this.
    06-28-2022 12:00 PM
  7. mustang7757's Avatar
    Yeah that and Bluetooth it Reset, hopefully everything will be good.
    06-28-2022 12:02 PM
  8. kgilbertsen's Avatar
    Ah, great, didn't think about BT... ¯\_(ツ)_/¯
    06-28-2022 01:13 PM
  9. mustang7757's Avatar
    Its good and bad as u have to set-up everything but needed when trying see if it fixes a issue
    06-28-2022 01:20 PM
  10. kgilbertsen's Avatar
    Yep, I'll survive it
    06-28-2022 02:00 PM
  11. mustang7757's Avatar
    06-28-2022 02:15 PM
  1. Why is my phone on Emergency Calls Only?
    By seanfitz88888 in forum Alcatel Android Phones
    Last Post: 06-28-2022, 11:02 AM
  2. Replies: 3
    Last Post: 06-28-2022, 10:59 AM
  3. Venmo app won't load on my phone
    By rscottea in forum Android Apps
    Last Post: 06-28-2022, 10:56 AM
  4. Active 2 cannot turn on
    By Android Central Question in forum Samsung Galaxy Watch Active 2
    Last Post: 06-28-2022, 01:20 AM
