Play store not work
Kaali
3
Install custom rom on galaxy note 3 but play store not work so what I need to do need both install rom and gapp install again plz help to solve play store problem cause nothing work like lots tools
Hi, welcome to AC!
You would have to check XDA Forums , they can probably help with the custom Rom you installed
Welcome to Android Central! I moved this to the Note3 Rooting/ROMs forum for more specific traffic.
First time install rom then everything fine but after two months custom rom not working properly so I try again install different rom that time I forget to I just install rom only ...can I now just Gapp install only it's possible
Dev on that phone probably have abandoned that device because it's very old so nit going get much support .
sshkjgh7788
