1. jayson_charles's Avatar
    im currently trying to upgrade my samsung galaxy note 3 n900T to the 5.0 lollipop firmware , usin odin and the lollipop fimware downloaded from sammobile i am getting Failed!! .... the error is NAND WRITE FAILED!! can someone please help me ?
    02-27-2015 03:34 PM
  2. Rukbat's Avatar
    Are you sure you're flashing 5.0 for the N900T? I don't see one listed on SamMobile. There are 5.0 files for other models, but not the T. The BEST result you can get from flashing a ROM for another model is a failure. In some cases it causes damage to the motherboard, and you have to have it replaced. You're lucky it failed. Wait until there's at least 5.0.2 for the T. (That's the bug fix for 5.0.1, which was the bug fix for 5.0, which was as buggy as a flea circus. Even 5.0.2 still has some bugs, but maybe you can live with them. Or wait for 5.1 and read some of the reports.)
    And back up everything before you even do an update (assuming you don't always have everything backed up, which you should - truck tires don't leave much data when they roll over a dropped phone).
    (In your other post you said N900. Which is it? The N900 isn't the N900T - they're different phones. A ROM for one won't work on the other.)
    02-27-2015 04:59 PM
  3. jayson_charles's Avatar
    thank you so much for youre response , the phone in question is n900T, well the update that i found on sammobile is for n900 and its an update in rissia , reading about the official update they said it can be manually flashed on any note 3 so i was trying to flash my phone, about the bugs im currently having trouble with my wifi where its just stuck on turning on , is this a hardware or a software problem ? i tried hardresetting it also i tried installing a custom rom but it still doesnt come on
    02-28-2015 09:36 AM
  1. Replies: 7
    Last Post: 03-04-2015, 10:40 AM
  2. How do I delete a goal in HabitBull?
    Last Post: 02-27-2015, 06:37 PM
  3. How do I remove the battery from my LG4.?
    Last Post: 02-27-2015, 06:34 PM
  4. Replies: 1
    Last Post: 02-27-2015, 05:18 PM
  5. Replies: 2
    Last Post: 02-27-2015, 04:50 PM
