1. superdave73's Avatar
    i have a verizon galaxy note 3 SM-N900V with firmware KNOX version 2.3 anyway i can root or a video that shows how to.. Thanks
    hussein ahmed2 likes this.
    05-29-2015 10:56 PM
  2. darthmilo69's Avatar
    Yes. If it's the same process of the AT&T model then you're going to have to roll it back to 4.4.2 to root. That's what I had to do to my AT&T Note 3.
    05-29-2015 11:51 PM
  3. superdave73's Avatar
    did you have to downgrade from the knox. if so where can i find these steps
    05-30-2015 12:17 AM
  4. NoEl surya's Avatar
    You could give a try with kingroot windows application. It's pretty easy.
    05-30-2015 01:07 AM
  5. Rukbat's Avatar
    There's a thread on XDA Forums for rooting it on 5.0, but it trips Knox. If it's on 4.4.2, Towel Root should do it.
    05-31-2015 06:46 PM
  6. Daniel j taylor's Avatar
    Any chance I could get the direct link to that XDA forum
    10-10-2015 03:13 AM
  1. My wifi on my S5 is grayed out, how can I get it to work?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 05-30-2015, 06:55 PM
  2. What is the best Bluetooth for the Galaxy S5?
    By randall102269 in forum Samsung Galaxy S5
    Last Post: 05-29-2015, 10:53 PM
  3. Need an USB cable for charging... in INDIA
    By rockz3r in forum Samsung Galaxy S4 Accessories
    Last Post: 05-29-2015, 10:52 PM
  4. Replies: 0
    Last Post: 05-29-2015, 10:45 PM
