1. laotzuology's Avatar
    I was thinking that, because the hardware for the Note 4's s-pen Air Command was in, well, the s-pen itself, the Note 3 might be capable of using that feature and other Note 4 s-pen specific features. Maybe by rooting? Does anyone know if it's even possible? I'm not that worried about whether it would fit in the phone or not.
    07-20-2015 05:42 PM
  2. SpookDroid's Avatar
    It will actually fit in the phone, just stick out because it's not the same length. That being said, Air Command does not 'reside' in the S-Pen. Yes, the hardware is compatible with Wacom's system (you can even use the S-Pen on a MS Surface and viceversa!), but the Air Command feature is purely software.
    So yes, it's possible to implement on the Note 3, and I'm sure someone out there has done so. I'm not too savvy on these hacking matters, but you'd need to root your phone and install a new ROM with that feature 'baked in'. There might be 3rd party apps that emulate this function (but don't really know if any exist though) and although I can't see why, they may or may not need root to work (in the end it's just a mini-launcher for your S-Pen).
    07-20-2015 06:13 PM
  3. Rukbat's Avatar
    There's a Note 4 port for the Note 3 on XDA, but I don't know whether they kept all the pen functions. (And it still has bugs.) Look for Note 4 Evolution.
    07-20-2015 09:18 PM
  4. Moshe Barash's Avatar
    Also some of the Note 4 s pen features are because of the newer Wacom digitizer, so those digitizer specific feature cannot be ported.
    07-20-2015 10:05 PM
  5. SpookDroid's Avatar
    Other than increased levels of sensitivity, any you can list?
    07-21-2015 11:41 AM
  6. Moshe Barash's Avatar
    Yeah, there was also another kind of sensor. It has to do detecting how far away the s pen is from the device and if it's tilted.
    07-21-2015 12:19 PM
  1. Note 4 to LG G4
    By divorceandroid in forum LG G4
    Last Post: 11-13-2015, 10:49 AM
  2. Which uk 4g network works with samsung scl23 (s5)?
    Last Post: 07-21-2015, 03:45 AM
  3. Replies: 3
    Last Post: 07-20-2015, 09:23 PM
  4. How do I send my Avatar Picture with email?
    By stevereenie in forum HTC One M8
    Last Post: 07-20-2015, 05:48 PM
  5. Replies: 0
    Last Post: 07-20-2015, 03:53 PM
