1. arobsum's Avatar
    i have an unlocked at&t note 3 i'm using with straight talk. how do i go about updating android? current version is 4.4.4. i've tried update device from settings...no help. thanks for your time.
    10-31-2015 07:32 PM
  2. Kelly Kearns's Avatar
    You can connect to Kies or the easiest thing, if you are close to a Best Buy, go there. They have a Samsung counter in Best Buy and they will update your phone for free.
    10-31-2015 08:21 PM
  3. arobsum's Avatar
    i've tried with latest version of kies...it doesn't give me the option of updating android. best buy sounds like a good idea though.
    10-31-2015 08:49 PM
  4. Kelly Kearns's Avatar
    If it isn't on Kies, Best Buy may not have it. What carrier is the phone?
    10-31-2015 08:59 PM
  5. arobsum's Avatar
    kies says i have the latest (4.4.4) i've seen most everyone else is at least 5.0. its an unlocked at&t note 3
    10-31-2015 09:11 PM
  6. Kelly Kearns's Avatar
    Well AT&T hasn't been good about getting updates back to Samsung, but you can try BB. Also if there is an AT&T Device Center near you, they might update it for you. 611 can tell you I'd there is one close if you don't know. The last option I know of if those don't work, buy a prepaid AT&T SIM, out $5 on it. It will cost you $15 for the SIM unless an AT&T manager decides to give it to you, and then connect to WiFi and check for an update. The SIM card has to be active.
    Oh.. If you know someone on AT&T, pop their SIM card in your phone and check for an update.
    10-31-2015 09:19 PM
  7. arobsum's Avatar
    cool. thanks. i appreciate the assistance.
    Kelly Kearns likes this.
    10-31-2015 09:21 PM
  8. arobsum's Avatar
    For anyone that's interested i contacted Samsung and they suggested going to best buy as well. Good call Kelly!
    11-01-2015 05:55 PM
  1. uninstall lollipop update moto G
    By Android moto G in forum Ask a Question
    Last Post: 11-25-2015, 04:01 PM
  2. Problem with Note 5 Camera
    By shapakin in forum Samsung Galaxy Note 5
    Last Post: 10-31-2015, 05:36 PM
  3. Replies: 1
    Last Post: 10-31-2015, 05:34 PM
  4. Replies: 1
    Last Post: 10-31-2015, 05:29 PM
  5. Replies: 0
    Last Post: 10-31-2015, 05:08 PM
