1. MrMLK's Avatar
    Questions About Wireless Charging cover-galaxy-note-3-accessories-hands-2.jpg
    Does anyone know any of the details related to the wireless charging cover? Does it add a lot of thickness? Will it still work if the phone is in a slim case? What is it supposed to cost?
    Thanks.
    09-12-2013 12:53 PM
  2. Preach2k's Avatar
    Yes it adds a little thickness. but not much. A friend of mine has it for his S4. It add a slight thickness.
    MrMLK likes this.
    09-12-2013 01:01 PM
  3. MrMLK's Avatar
    Yes it adds a little thickness. but not much. A friend of mine has it for his S4. It add a slit thickness.
    Thanks for the info. DOes he keep his phone in a case? If so, does he need a non standard case, or will it still squeeze in?
    09-12-2013 01:11 PM
  4. Preach2k's Avatar
    No he does not use cases. But I think it can still use an case if he wanted to. I do not know if the case would interfere with the charging.
    09-12-2013 01:24 PM
  5. Raptor007's Avatar
    Good question about cases and the wireless charging. I was always told that it added enough bulk to make the standard cases not fit properly so I simply skipped over that feature. I would like to have it, but not if I can't fit it into a regular case.
    09-12-2013 09:19 PM
  6. gnik luap's Avatar
    I bought the same product for the S4. The back is thick enough that the camera lens is now recessed slightly. That's great if you want to protect the camera but not good if you use a hard case. I used a poorly fitting bumper, some others used TPU cases.
    You can look on the xda developers site, S4 accessories, wireless charging & find more info about the issues for this with S4. I'm hoping the Note 3 wireless charging back is thinner.
    10-03-2013 08:28 AM
  7. thegame161's Avatar
    ordered one and a charging pad.
    10-03-2013 11:50 AM
  8. MrMLK's Avatar
    Where do you order it from? I want to get one too. Thanks.
    10-03-2013 12:03 PM
  9. thegame161's Avatar
    Depends where you are...i'm in the UK.
    it's from mobilefun.co.uk..great site but might be useless if you are in the US.
    10-03-2013 12:35 PM
  10. vzw8830's Avatar
    You can also get the qi charging slip and just attach it between the battery and the back cover. Im sure it makes the stock cover stick out though as with the gs4. I just looked on ebay, dont see any listed for the n3 yet, just the n2, gs3 and gs4.
    10-03-2013 09:51 PM
  11. dontlookatme's Avatar
    i would like to get the case for wireless charging. since i already have a wireless charger from Qi.
    10-03-2013 10:31 PM
  12. DCSholtis's Avatar
    Mobilefun.com has them as well. Its their US site. They also say the wireless charging S View cases should be in around 1-2 weeks. Im holding out for that.
    10-04-2013 04:35 AM
  13. vzw8830's Avatar
    Found one for the note 3
    10-12-2013 06:27 AM
  1. Replies: 20
    Last Post: 04-12-2014, 10:32 AM
  2. What I like and don't like about the Moto X
    By jimbarr in forum Moto X
    Last Post: 09-12-2013, 09:22 PM
  3. about the New function
    By wufang640 in forum Samsung Galaxy Note 3
    Last Post: 09-12-2013, 09:16 PM
  4. help about samsung i9505G problem
    By wufang640 in forum General Help and How To
    Last Post: 09-12-2013, 10:44 AM
  5. [Q]About My HTC Glacier`s Screen lost respond
    By iankicksurass in forum HTC myTouch 4G
    Last Post: 09-12-2013, 06:54 AM
