1. Android Rage's Avatar
    I want to buy the unlocked Samsung Galaxy Note 3 from Verizon Wireless on the $699.99 plan and bring it over to the UK. Unlocking is not a problem because if the handset doesn't come unlocked, I can get it unlocked. My question is whether the phone will work with LTE, HSPA+ and 3G in the UK. Here are the network specifications directly off of the Note 3 page on Verizon Wireless' website:
    CDMA Data 1x and EVDO Rev0/RevA
    LTE: B13 (700MHz)
    Global Ready (GSM/EDGE: 850/900/1800/1900;
    HSPA/UMTS: 850/900/1900/2100 MHz)
    For reference, I am on the Virgin Mobile VIP monthly SIM only deal. Virgin don't currently have 4G services but will soon, and I'm wondering if the handset would work on it when it becomes available.
    Thanks in advance
    AR
    09-13-2013 12:34 PM
  2. dpham00's Avatar
    What are the specs of the UK network that you are on?
    Sent from my Verizon Samsung Galaxy Note II via Tapatalk 4
    09-13-2013 12:39 PM
  3. thefireguy286's Avatar
    Verizon LTE phones are SIM unlocked out of the box as has been required per the Block C spectrum regulations. The phone would work on all networks up through HSPA+. Virgin UK is really EE, you will just have to change the default APN settings. As far as I know UK LTE is in entirely different bands (800/1800/2600 i believe) so LTE won't work there on a US Note 3.
    09-13-2013 12:59 PM
  4. Android Rage's Avatar
    Thanks for the reply. Would you know how to (where to find related information) change the appropriate APN settings? Also is there a software modification available to change the LTE band reception of the Note 3 (assuming the receiver can receive the UK LTE bands). If the receiver cannot receive UK LTE bands, can a hardware modification be performed?
    Thanks
    AR
    09-13-2013 01:07 PM
  5. Android Rage's Avatar
    Forgive me for asking an easily Google-able question (with regards to changing the APN settings), the answer to which I have just found by googling. I couldn't find answers to the other two questions (software mod or hardware mod).
    Cheers
    AR
    09-13-2013 01:14 PM
  6. thefireguy286's Avatar
    Thanks
    AR
    No and no, they can't be changed. Why not just buy the UK version?
    09-13-2013 01:44 PM
  7. Android Rage's Avatar
    Ah ok. Thanks. The UK version is $330 (208) more.
    09-13-2013 02:03 PM
  1. Hello from a small indie dev team in SF/Bay Area!
    By EkataSystems in forum New to the Forums? Introduce Yourself Here!
    Last Post: 09-16-2013, 01:59 PM
  2. Looking for opinions on the gpe ROM...
    By jec11718 in forum Verizon Droid DNA
    Last Post: 09-15-2013, 03:42 PM
  3. fonts on the s4
    By cachun402 in forum Samsung Galaxy S4
    Last Post: 09-14-2013, 01:34 AM
  4. How are the radios on Verizon
    By Umass021 in forum LG G2
    Last Post: 09-14-2013, 12:13 AM
  5. Universal TV and dvd remote
    By mcookson in forum General Help and How To
    Last Post: 09-13-2013, 12:31 PM
