1. Matt D Cooper's Avatar
    Hi,
    Just got my Note 3, my first android device!
    And I have a couple of problems, I have 2 Exchange email accounts, 1 of them is perfect and has sync'd all folders. The second one has chosen to sync 4 folders out of the 12 I have?! I have removed the account and re added it and its still not there, so im confused why its doing this? It didn't do this on my iPhone, iPad or via Outlook on my PC.
    Also the second this is that I have migrated from the iPhone using the easy sync tool, all is fine except notes which I had a lot of! which on the Note 3 appear in an xml file all as one, and not readable! any ideas how I can get these onto my Note in a similar format?
    Thanks
    Matt
    09-29-2013 12:20 PM
  2. EvilMonkey's Avatar
    For email, are you using the stock email app? If so, go into menu -> Settings and choose the account. About 1/2 way down is a "Folder sync setttings" option which you can select and specify your sync settings for individual folders.
    Hope that helps.
    For notes, I don't have experience with it, but did a bit of research and people say this works:
    Smartphone Content Transfer Made Easy | Samsung Smart Switch
    09-29-2013 05:38 PM
  3. Matt D Cooper's Avatar
    Hi, thanks for the reply ,
    Checked the email settings but they only show 4 out of the 12 folders, so something else is wrong .
    Cheers ill take a look at that
    Matt
    09-29-2013 06:50 PM
  4. chevyman29's Avatar
    Matt
    there is a app in the market called file converter that may help with your files.
    09-29-2013 08:26 PM
  1. few questions before I start
    By john6969 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 09-30-2013, 01:03 PM
  2. Battery charge Question
    By Ductman1 in forum Moto X (2013)
    Last Post: 09-29-2013, 11:41 AM
  3. AT&T SGS3 - Google Voice call problems
    By hunterx82 in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 09-29-2013, 10:09 AM
  4. AT&T SGS3 - Problems with Google Voice?
    Last Post: 09-29-2013, 10:02 AM
  5. Verizon Upgrades Allowing Retention of Unlimited Data
    By fwhomeboy in forum Verizon Galaxy Note 2
    Last Post: 09-29-2013, 08:24 AM
