So when it's in power saving mode it will let 3 of the cores go idle, but when there's an intense workload it will turn on all 4 cores?
Pardon me, but that isn't a bug, it's a feature. You save battery when you don't need it, and when you do need it, all four cores of the CPU will actually be engaged.
Seems pretty normal Linux kernel behavior to me. Which is what Android is built on top of.
If the reviewer's going to complain about anything, they should complain about using synthetic benchmarks in the first place.
not even the same thing as a PC. A PC doesn't raise frequencies high on just benchmarks. It does it with games also which the Note 3 doesn't. All it does is raises the frequency during benchmarks and nothing more.
AnandTech's Review:
AnandTech | Samsung Galaxy Note 3 Review
"CPU performance is honestly excellent. The Galaxy Note 3 is more or less the fastest Android smartphone we've tested up to this point. In the situations where we can do cross platform (OS/browser) comparisons, it isn't quite as fast as the iPhone 5s but in some cases it comes close. I should mention that the Note 3 (like many other Android devices - SGS4, HTC One) detects certain benchmarks and ensures CPU frequencies are running at max while running them, rather than relying on the benchmark workload to organically drive DVFS to those frequencies. Max supported CPU frequency is never exceeded in this process, the platform simply primes itself for running those tests as soon as they're detected."
It's also interesting to note that the Galaxy Note 3 appears to outperform all other Snapdragon 800 smartphones we've tested thus far. There's a couple of potential explanations here. First, the Galaxy Note 3 is using newer drivers than any of the other S800 platforms we've tested:
Note 3: 04.03.00.125.077
Padfone: 04.02.02.050.116
G2: 4.02.02.050.141"
Move along folks, nothing to see here.
There's absolutely plenty to see here. The fact that many manufacturers are doing this doesn't excuse it, either. It wasn't ok with the PC market, and it shouldn't be ok with the mobile market.
Why are we comparing apples to androids ?
The iphone pushes sub 720p .... the note 3 is pushing 2.5 times the pixels... no **** it is going to take a split second faster to load
